Home > V8 > Misfires are back!
Page 4 of 8 <12345678>
muddypaws
England 2009 Defender 90 Puma 2.4 SVX Station Wagon Santorini Black
Been down this long road with my old cobra
- you've not got a rev limiter fitted have you? Richard
Defender 90 SVX
Post #584372 12th Dec 2016 8:49am
charcoal
United Kingdom 2005 Defender 110 Td5 HT Bonatti Grey
I don't think so, I thought the revs were only limited by how fast the tappets and valve springs can run? How would I identify a rev limiter? 1999 Land Rover Defender 110 td5 station wagon
1998 Land Rover Defender 110 County Station Wagon ~ Sold
1995 Land Rover Defender 110 V8 Station Wagon ~ Sold Sad
1985 Land Rover 110 ex mod project Tithonus ~ Sold Sad
Post #584479 12th Dec 2016 4:56pm
muddypaws
Usually a little black aftermarket box about the size of a matchbox with a couple of wires heading onto the coil
Mine started to malfunction after a winter hibernation & instead of kicking in at 6.5K, it started working at 1.8K & caused no end of head scratching. Richard
Defender 90 SVX
Post #584544 12th Dec 2016 7:29pm
muddypaws
here's the one I had Richard
Defender 90 SVX
Post #584549 12th Dec 2016 7:32pm
charcoal
Ah, I have nothing like that. Maybe it was only fitted to sporty type cars? 1999 Land Rover Defender 110 td5 station wagon
Post #584656 13th Dec 2016 12:07am
muddypaws
Just a thought......
BTW no one has mentioned the rotor arm yet; crack in it, poor connection on pillar etc
I believe it still sounds electrical not fuel - esp if the age old trick of a little choke when it is happening makes no difference Richard
Defender 90 SVX
Post #584675 13th Dec 2016 7:36am
charcoal
The rotor arm was replaced along with the distributor body the other month and made no difference. That's what was making me think it was electrical too but I've replaced every electrical component now and nothings been solved. Confused 1999 Land Rover Defender 110 td5 station wagon
Post #584926 13th Dec 2016 11:58pm
muddypaws
Hmm....can you reproduce the misfire when not under load?
I attached a strobe light to the leads in turn, then produced the misfire by reving whilst stationary.
This way you can find out if it is the HT circuit ie king pin, or individual leads.
Of course if no misfire when stationary then you cant Sad Richard
Defender 90 SVX
Post #584951 14th Dec 2016 8:38am
charcoal
Can't reproduce it without load Sad Sometimes when if it's bad enough you can pull over and it's still misfiring but by the time you got a timing strobe set up it would be back to normal. 1999 Land Rover Defender 110 td5 station wagon
Post #584974 14th Dec 2016 11:00am
muddypaws
Its starting to sound more fuel related I reluctantly admit although that wouldn't cause the backfire you describe.
What is strange is that the RV8 is such a forgiving engine in such a low state of tune, I'm amazed its misfiring; my old RV8 put out 325bhp & when it wasn't fuelled right, it was just be slower but never misfired (except when I mistimed the dizzy Embarassed & also had the rev limiter issue) Richard
Defender 90 SVX
Post #584985 14th Dec 2016 12:20pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Have you had a go at running a tempory fuel feed?
5ltr can sat on wing or bonnet straight into carbs... 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #585001 14th Dec 2016 1:18pm
charcoal
The recent backfires sound like exhaust ones, they are quite quiet compared to the one I described in detail which must've been an intake one. Could be normal as I heard they can do that while accelerating at cold temperatures? I haven't hooked it up to a temporary fuel source, why would I need one? 1999 Land Rover Defender 110 td5 station wagon
Post #585485 16th Dec 2016 12:12am
Morepower
New Zealand
Hi Charcoal...
Sounds like your fighting some serious issues there... In my experience, This could be down to a few things... Your timing could be jumping around... or you have a seriously lean mixture... or very rich... Reading back, you say it's been on a rolling road... I would suggest going back and trying to emulate the issues... You should be able to see the timing moving if thats the issue with a strobe whilst it's under load and the lambda will give you a good idea of where the mixture is... Although I would recommend also running a HC meter to analyse how the mixture is burning as Lambda sensors can invert in the extremes... I.e dangerously lean can look rich and vise versa... However, any good dyno operator should know this, and usually the figures will tell the story, too lean and the graph will look raggy, like wise for too much advance...
Hope this helps
Regards
Tim It doesn't matter how bad it is, It can always get worse...
2013 Bowler 110 (Sold)
2016 Bowler 90 Rally Spec (Sold)
Post #585505 16th Dec 2016 6:43am
I'm still intrigued to what's wrong. Everything is all bolted up tight? Headers, inlet manifold, etc etc.
Alex who owns Staffs 4x4 is pretty much a v8 guru, we had a TVR in that wouldn't run right, it went to a few garages before coming to us and he quickly diagnosed the plenum was not sealed right and once sealed, ran fine.
Post #585507 16th Dec 2016 6:54am
ian series 1
It would eliminate any fuel supply problems from the tank to the carbs.
At least then you know for sure it's not anything related?
And you can move on to the engine itself. 80" 80" 86" 88" 90"
Post #585512 16th Dec 2016 7:14am
