Home > Puma (Tdci) > Problems out of the blue |
BigMike Member Since: 13 Jul 2010 Location: Lancashire Posts: 2253 |
Battery suggests alternator
Clunk suggests clutch Hard to say without more info |
11th Feb 2011 11:51am |
JSG Member Since: 12 Jul 2007 Location: Berkshire Posts: 2412 |
Hi,
From what you say it seems the battery may have drained when it was left (unless, as suggested the alternator hadn't been charging it and it was flat ish when you left it). Does it have an alarm / immobiliser or other stuff that draw any current with the ignition off? As to the noise, do you hear it in neutral and in all gears - or just neutral when idling? If it goes when the clutch is depressed it is related to the gearbox and beyond. It it is only when in gear maybe something on the prop side of things - if it is there in neutral then my guess would be something around the area of the input shaft to the gearbox as this turns in neutral until you depress the clutch. Cheers, John John http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
11th Feb 2011 12:50pm |
diffbeer Member Since: 18 Nov 2008 Location: Farnborough Posts: 44 |
Thanks Guys
Found the culprit -- a mobile phone charger plugged into a aux cigarette plug in the back of the vehicle. Had a mechanic look at it -- seems to be the " Release bearing" playing up. Anyone had problems with this before what causes it to break or damage? |
11th Feb 2011 3:23pm |
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 |
Yep i've had 2 new clutches because of the release bearing going.... it is defiantly your release bearing as said when you press the clutch in it's gone NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
11th Feb 2011 3:59pm |
Searching on the forum it seems it is common to have clutch issues - Is there perhaps a aftermarket Heavy duty one that would be better to replace the existing one?
11th Feb 2011 4:19pm |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 |
Is it still under warranty?
There was a service bullitin issued about clutch problem .. had mine replaced just before warranty expired |
12th Feb 2011 2:07pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5059 |
True but the replacement doesn't always fix it! Mike |
12th Feb 2011 4:01pm |
