Home > Puma (Tdci) > Puma squeal
Jed
United Kingdom 2007 Defender 110 Puma 2.4 DCPU Cairns Blue
Puma squeal
Started to get a squealing sound from engine, sounds a bit like a belt squeal, doesn't do it under acceleration or deceleration but only when the engine isn't under any load but can be at any revs, doesn't do it on tickover either, I've had the puma 2.4 Bass remapped and there is no loss on power. Can anyone help it would be much appreciated
Post #582635 4th Dec 2016 1:34pm
Ancillary drive belt slip maybe. No Guts, No Glory.
🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª
Post #582649 4th Dec 2016 4:12pm
Jed
Thanks for reply but would it only slip when under light load
Post #582668 4th Dec 2016 5:20pm
Very variable, bearings on pulleys is another possibity but I'm say the belt is more likely.
What miles have they done? No Guts, No Glory.
Post #582669 4th Dec 2016 5:24pm
Jed
The miles read 79000 on a 07 plate,I have no idea how old belt is
Post #582734 4th Dec 2016 9:03pm
ickle
new belt at 60K?
Post #582738 4th Dec 2016 9:11pm
Jed
I will try a new belt, is it an easy job and thanks for your response
Post #582750 4th Dec 2016 9:51pm
Mines due shortly then @ 60k I'm on 55k.
They are relatively cheap, around £35 IIRC Genuine.
Sadly I don't know the P/N off the top of my head.
Easy to change yourself, a little more complicated if you have A/C but nothing to worry about.
Disconnect battery, remove fan cowling, slacken AC drive belt tensioner, remove belt.
Refit new repeat in reverse the above. No Guts, No Glory.
Post #582755 4th Dec 2016 9:57pm
dorsetsmith
Whistle
Post #582759 4th Dec 2016 10:03pm
dorsetsmith
PQS500610 non AC drive belt 2.4
PQS500600 with AC drive belt 2.4
Post #582761 4th Dec 2016 10:05pm
Jed
I think I can do that. Thank you again for your help
Post #582762 4th Dec 2016 10:05pm
Job jobbed. Razz No Guts, No Glory.
Post #582766 4th Dec 2016 10:10pm
agentmulder
Kuwait
Mine was the tensioner pulley bearing.
I put some WD40 in as a test to see if it would go away, it did, been running that way since Embarassed Laughing
Should really replace it or syringe some proper lube past the seal.. Solved the bowel problem, working on the consonants...
Post #582796 5th Dec 2016 5:58am
hornet
Bearing of pulley (PQG500210) is a standard "6203". No need to do the whole assembly -- except for spare part-reasons.
Post #582799 5th Dec 2016 6:43am
agentmulder
Kuwait
^^ Thumbs Up Solved the bowel problem, working on the consonants...
Post #582802 5th Dec 2016 7:32am
