![]() | Home > Puma (Tdci) > RedBooster servo clutch |
alastaid Member Since: 03 Dec 2013 Location: York Posts: 78 ![]() ![]() |
Hi,
I have just had one fitted to mine, to be honest it was out of necessity as I am on my third left knee op of the year, and the redbooster means I can keep my Defender. I also have a slickshift, all being well I will be able to drive again next week so I can report back on how it drives. Cheers Alastair |
RoddyK05 Member Since: 08 Apr 2015 Location: Inverclyde Posts: 633 ![]() ![]() ![]() |
For info, try emailing Rod Barry the UK importer. I'm sure he had one fitted to his own Puma, he can tell you all about it. Just got one fitted to my Td5 by him, it's super light. No accelerarated wear on the clutch as it only works when you press the clutch pedal. If you drive with your foot resting on the clutch, then yes it will cause premature wear problems, but that's a problem with driving style and not the unit. Rod will be happy to answer any questions you might have. Get him on: roderick@johnbarry.co.uk Hope this helps.
Dynaglide Member Since: 24 Aug 2012 Location: Sheffield Posts: 14 ![]() |
Hi had one fitted on mine for well over a year, best thing I've done, a much more relaxed drive.
I had to move the coolant reservoir to the passenger side, mounted on the plastic inner wing. I always park in gear and the vacuum tank will hold some pressure for a few days after that it is a little harder to press the clutch peddle before starting. |
