Home > Puma (Tdci) > Noise and heat of new gearbox.... whats normal.
mhasting2004
Australia 2008 Defender 110 Puma 2.4 SW Stornoway Grey
Hi Guys
Well I've been driving around our new 110 puma (replacement for our old td5 which cracked its head Sad ) And I have the following question.
The drive line seems noiser than the old one, no in a broken way but more of a gear mesh noise. Also it generates a lot of heat which is transfered to the floor area behind the front seats. This can get hot to the point of being uncomfortable to touch after a 1 hour highway drive at 120 km/h. I remeber the old TD5 would also get hot but not as much and especially not if unloaded. I tow a boat sometimes.
The old gearbox had a copper pipe radiator of sorts for the gearbox and the new one has nothing from what I can see.
Is this normal? And is it possble to add an oil cooler to the new gearbox?
Mark
Post #5824 1st Jan 2009 12:23pm
mse
There have been a few cases of the handbrake drum making contact in use, could explain the additional heat and noise. Mike
Post #5828 1st Jan 2009 4:01pm
Eduardo
Mhastings2004
Our also get hot in the front passenger side but after several hours at 120 km/h and not strange noises.
Better to check! Eduardo
Post #5841 2nd Jan 2009 4:10am
mhasting2004
Thanks for the replies.
My hand brake was sticking a bit previously and has been adjusted so that does not seem to be an issue. Am quite familiar with those symptoms of a stick brake. Still not 100% happy with the hand brake as I feel its just out of round and slacking off the adjustments is not really a cure.
Like I posted earlier the gear train noise is not that bad by any means just differeent to our old TD5. then again it may be because the new car is quieter in general that I can now hear these other noises Rolling Eyes
I had insulated the floor on the old girl prior to going outback so maybe its just that I need to do the same again on the new one.
Is there a gearbox oil temp sensor on the new box? I really need to get a copy of the shop manual as the owners manual tells ya nothing.
Mark
Post #5845 2nd Jan 2009 1:56pm
Eduardo
mhasting2004
You can get the workshop manual at www.landrovertechinfo.com paying a fee for day/month/year access.
Its a good idea to do it (at least you can download what you need for future reference)
Cheers! Eduardo
Post #5846 2nd Jan 2009 2:28pm
mhasting2004
Does a subscription allow you to down load the manual or only view it? Cheap one way very expensive the other.
Mark
Post #5847 2nd Jan 2009 3:25pm
Eduardo
You can print it
I use Adobe Acrobat to "print" the manual in a PDF file for reference and to do not have tons of paper
Its tedious because each section are independent and you cannot print all at once.
but with some patiente can be done in few hours of work.
Regards Eduardo
Post #5848 2nd Jan 2009 3:31pm
mhasting2004
Cool I'll do that. Might try a html to pdf coverter also.
Mark
Post #5849 2nd Jan 2009 3:33pm
