Home > Puma (Tdci) > Fuel gauge failure |
yaho Member Since: 26 Nov 2008 Location: Bialystok Posts: 200 |
After some unusual readings (indicated fuel level too low) the gauge sits down at zero now, reporting low fuel alarm each time I start the engine.
I wonder what will happen if I continue to drive - will fuel management system stop the engine after certain number of kilometres to prevent total out of fuel? Janusz www.yahodeville.com |
2nd Dec 2016 8:05pm |
log11 Member Since: 31 Mar 2009 Location: ATHENS Posts: 28 |
i have the same problem.
Any solution? |
5th Dec 2016 12:15pm |
Eventually the ECU will start to make the engine misfire, then it will cut out and only allow you to drive a mile at a time to protect itself.
http://www.defender2.net/forum/topic35577.html http://www.defender2.net/forum/topic30145.html
The solution is to fix the sender |
5th Dec 2016 12:48pm |
I have an early Puma I guess. 115 km on 'empty' and still going on without misfire.
Build date: Feb 2007. Janusz www.yahodeville.com |
5th Dec 2016 4:54pm |
1. check wiring only two wires with multimeter may open cct
2. fuel sender may be open cct Click image to enlarge |
5th Dec 2016 5:08pm |
Thank you! I was just looking at the same diagrams.
As far as I understand, the fuel level sensor is resistor type. Do you know the min-max values of the resistor? If known, I can plug proper resistor into the connector at the tank and see what the gauge shows. Or there are easier ways to check it? Janusz www.yahodeville.com |
5th Dec 2016 5:31pm |
Disconnecter at the tank and at the instrument panel short out two pins con check at instrument end if you can or disconnecter instrument panel end and con check from end ether way it going to to be
5th Dec 2016 6:10pm |
Janusz
5th Dec 2016 6:55pm |
As the follow up to the story. I have removed suspected gauge and investigated the sensor. It is encoder, not resistance type, so will not show any resistance (open / infinity). See the pictures.
Click image to enlarge Click image to enlarge Janusz www.yahodeville.com |
14th Aug 2017 4:54am |
