Home > Technical > Cloning |
Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897 |
Is it possible to clone a remote?
9th Feb 2011 3:24pm |
BigMike Member Since: 13 Jul 2010 Location: Lancashire Posts: 2253 |
Not sure this is a good topic for discussion tbh
9th Feb 2011 3:26pm |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4615 |
Land rover maintain that the short distance that the remote can be from the car before it can be used is to stop someone capturing the signal and therefore getting access to your car. So I would say yes, your remote can be cloned. Need to get it recoded or get a new handset and get that and the vehicle reconfigured. 1982 88" 2.25 diesel
9th Feb 2011 4:59pm |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
well they did a sheep 2.4 90 XS
10th Feb 2011 9:06am |
mrandmrsh Member Since: 31 May 2010 Location: Huddersfield Posts: 692 |
Haven't we all |
10th Feb 2011 12:41pm |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
Laurie, the 10AS .............
Spudfan, it's the length of the aerial on the Puma's 10AS unit which forces you to be near the landy when disarming. EDIT: Removed the techy bit Last edited by Lorryman100 on 10th Feb 2011 2:37pm. Edited 1 time in total |
10th Feb 2011 1:08pm |
Thanks for that
I'm not in need of technical stuff but would like to know if someone could open my (TD5 XS) Defender within a few minutes of my locking it, leaving the vehicle as if I'd just forgotten to lock it. A simple yes or no will suffice as, already pointed out, the technicalities are best not discussed on here. |
10th Feb 2011 2:03pm |
Yes.
10th Feb 2011 2:07pm |
MrFlips Member Since: 27 May 2009 Location: Cardiff Posts: 682 |
I returned to mine last year to find it unlocked and believed that a similar thing had happened, but later close inspection of the door just underneath the door handle revealed an altogether less sophisticated form of keyless entry. Peter
2008 SWB Truck Cab 1952 80" Soft top |
10th Feb 2011 2:27pm |
Thanks
10th Feb 2011 2:34pm |
