![]() | Home > Puma (Tdci) > Possible leak |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1822 ![]() ![]() ![]() |
Keep topping up, I don't think modern engines like rad weld etc. chokes the galleries and causes hot spots in heads etc....
I've had a tiny leak on the heater valve for five years, takes a cupful every 6 months! |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20613 ![]() ![]() |
Yes, as I was advised correctly here too - don't use any radiator fix stuff, if it's very minor leave it alone.
You can change the cap if you like, it may help and little money to use. Keep topping up for now, if it gets bad you'll soon know then it'll be time for an actual fix. As suggested, you'll probably go on for years no problem. Keep an eye on it for topping up purposes, other than that I wouldn't worry. Chillin In The Backwoodsπ¬π§πΊπΈ β½οΈπ’οΈβοΈπ§°πͺ |
churchy Member Since: 28 Jul 2011 Location: UK Posts: 237 ![]() ![]() |
Great thank you.
