Home > Puma (Tdci) > Puma Engine "Pull" Problem in 6th Gear |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 |
I had a similar problem. It was a small tear in a turbo hose that only opned up under load and only noticable in 6th when cruising at lower revs using torque.
1st Nov 2016 8:45pm |
Ziggy Ghana Member Since: 01 Nov 2016 Location: Accra, Ghana Posts: 5 |
Thank you bm52 for the help. When I ordered the turbo unit I asked the supplier in the UK to supply all hoses needed for the connection, but the supplier failed to do so. The supplier also mentioned possible tiny tears in these hoses.
I will try and find the part numbers for all the turbo hoses and order them. I'll let you know what happens. |
1st Nov 2016 8:55pm |
bm52 I will checked intercooler hoses and they are fine.
Please let me know what other things to look at. Does anybody else have any ideas? |
13th Nov 2016 9:22pm |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10376 |
Ziggy, have you actually taken the hoses off to look at them? bm52 is right, they open up under pressure and difficult to see anything when they're fitted.
13th Nov 2016 9:52pm |
Dieselhead Member Since: 21 Oct 2012 Location: Pulborough. West Sussex Posts: 552 |
What about the pressure relief valve on the end of the fuel rail Chris
2008 XS 110 2.4 Utility. Tonga Green 1953 Series 1 for restoration 1983 Mini Mayfair 2004 VW T5 Camper 2008 Diahatsu Sirion. Thats hers Classic Bolens Garden Tractors |
14th Nov 2016 8:30pm |
Thanks for the contribution Dieselhead.
I will send the vehicle to workshop tomorrow. I will take pictures of hoses for this group to show evidence of the state of the hoses. Dieselhead, I will also let the workshop mechanic trouble shoot the pressure relief valve at the end of fuel rail as you have suggested. Look forward to getting some results this week. I will let you have the feedback guys. Thanks again for all the ideas. |
14th Nov 2016 9:51pm |
I got the car back today with no change. All the hoses were removed, checked and replaced and then re-tested with engine revved.
I am a bit frustrated. I also have a "hard clutch" problem as well which makes in traffic driving not enjoyable. Can anyone recommend a workshop in South Africa which specialises in and has extensive expertise with Defender repairs as well as overland accessorisation. I'll think of shipping the car there for repairs and an extended holiday. I' appreciate any advice and recommendations. |
25th Nov 2016 11:15am |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2623 |
Ziggy, you can use LandyWorx in Joburg. One of the best LR indies in ZA
http://www.landy-worx.co.za/ -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
25th Nov 2016 11:48am |
xpertoftheseas Member Since: 05 Jan 2016 Location: Salisbury, Wilts Posts: 164 |
Wow. You have spent a whole lot of money looking for this fault and no joy. The good thing is you have ruled out a lot of the obvious. It would seem extremely strange to me that you are only experiencing this in 6th gear. If the truck has had dirty fuel previous to you owning it then you would have no idea how much power the truck should have if being run on purely good fuel. I would suggest that in general you are not getting the full power or torque in any gear, its just that 6th would show it more due you the higher powers and torque needed to drive this ratio. First - fuel pressure! Dirty fuel will catastrophically ruin the high pressure pump so you need to get this measured at full load. This means in 5th gear 2000rpm foot to the floor and same in 6th if you can get it there. Post the pressures. Second. Fuel rail pressure sensor. These can get blocked and damaged by dirty fuel and give the wrong readings to ECU (ie if your sensor is reading 500bar when engine is off then possibility is that ECU is getting 500bar more reading causing ECU to demand a lower (wrong) pressure from the pump) Third. Get it on a dyno. This will show you what it is outputting to the wheels and will confirm your concerns. Fourth (and to eliminate the last obvious) check accelerator movement is not fouled by carpet etc and moves full span to mechanical stop) All of your posts would suggest fuel is the problem so I would highly recommend you have some investigative works done here. Common rail engines need very clean fuel and any dirt can quickly damage the HP pump, flow control valves, sensors and injectors. Let us know how you get on. My 10th Land Rover, but my first Defender. |
28th Nov 2016 1:47am |
Ferdinando Member Since: 05 Apr 2015 Location: Lisbon Posts: 4 |
Hi,
i have a similar problem, i just replaced the VCV valve, cleaned the tank, fuel filter change, MAP sensor replaced, but still the same. i even took out the snorkel and checked the air filter. i think itīs not just in 6th gear, but it becomes more perceptive under pull in 6th. best regards |
2nd Dec 2016 12:18pm |
Wild Card 90 Member Since: 03 Dec 2014 Location: Gerlingen Posts: 1060 |
Ziggy,
it seems pretty clear that your Puma just isnīt producing the 120 or so hp that it should. You have covered many of the issues that will strangle it and cause a loss of power. Induction, injection, turbo. Does it use or lose oil? In view of the dirty fuel (fuel tank, pump, injectors) you mentioned, could it be suffering from a semi-blocked cat or DPF? Stephen 1998 Tdi 90 SW, 2008 Td4 90 SW, 2012 2.2 90 SW, 2" raised Trailmaster/Terrafirma Heavy Track Raids, 255 MTīs, Recaro CSīs, anorak, wellingtons |
2nd Dec 2016 2:51pm |
