Home > In Car Electronics > Td5 interior light
01rwilkinson
England 2001 Defender 90 Td5 HT Rutland Red
Td5 interior light
Help I have a td5.my interior lights will not switch off automatically does anyone have any clues I have
Put three new door switches in the lights will turn on and off manually but when the cab switch is in the middle position
The light stays on
Post #579947 23rd Nov 2016 8:45pm
miker
Probably means one of the switch wires has rubbed through to ground somewhere. Unfortunately it's some old fashioned wire tracing to figure out where!
Post #579949 23rd Nov 2016 8:53pm
Vogler
Belgium 2015 Defender 110 Td5 HT Chawton White
Did you install the switches to solve the problem, or was it caused by installing the new switches?
If I'm not mistaken the wires in the door contacts are earthing the light, so if the wire is damaged and makes contact to the body the lights will go on.
Edit: posted simultaneously with the previous post.
Greetings,
Joris
Post #579950 23rd Nov 2016 8:55pm
01rwilkinson
Td5 interior light pink
Hi I installed switches to solve problem didn't work .will check wires for earthing out thanks.
Post #579963 23rd Nov 2016 9:25pm
Cupboard
Before it all went wrong, did it have a delay on the light turning off?
Do you have an alarm?
I was under the impression that all of them that age did but it's worth checking.
There's a 12V permanent feed to the interior light, then the switch selects between off, on (direct connection to ground) and auto, which connects it to the 10AS (alarm unit) or through the doors if you don't have a 10AS. The wire goes down the front pillars in to the back of the dash, but it's in a loom with a load of others.
Post #580028 24th Nov 2016 7:21am
roel
All td5's have the AS10.
I had the same problem. My problem was that the 1984 doors don't have the extensions that push the switches in. Whistle So I don't have an interior light anymore. Twisted Evil Roel
2003 90 Td5 (2009-now)
Post #580070 24th Nov 2016 9:38am
01rwilkinson
Hi there before everything went wrong yes I had normal cycle .
Lights came on when remote was pressed and so did alarm and they went off when I locked vehicle
Now when I lock vehicle they stay on unless I turn the cab switch to the off position..
Post #580160 24th Nov 2016 6:28pm
Cupboard
Stay on forever, or stay on for 10 minutes?
What pattern of flashes is the little red light on the dash doing?
You can narrow things down a bit using the little red light, because it has different flashes for driver's door, non driver's door and all closed. If the light never goes out then it's either a faulty 10AS alarm unit or a fault with the wiring from that to the light. If the light goes out after 10 minutes then it's a problem between the doors and the alarm.
Post #580312 25th Nov 2016 7:36am
01rwilkinson
Interior light
Interior light switch in middle position, light on door shut, light on dash flashing steady one second intervals.
When I lock vehicle with key fob dash light flashes rapidly for a few seconds then settles down to one second intervals.
Have had front roof lining out cleaned wiring socket with electrical spray .
Can't find anything obvious.
Post #580455 25th Nov 2016 5:41pm
Cupboard
That sounds perfectly normal.
It's a shame the 10AS is such a fiddle to get to, but I think the next step would be to try and unplug the feed out of that.
It really does sound like a short to ground somewhere.
Post #580790 27th Nov 2016 3:53pm
01rwilkinson
Hi there.happy new year to all
Just a quick question about my td5 defender still chasing interior light fault,
Does anyone know where I can find the 10as or as10 unit thanks.
Post #589342 1st Jan 2017 11:25pm
Baz8046
United Kingdom 2002 Defender 90 Td5 HT Rutland Red
The unit is behind the dash along with a few of the relays on the Td5.
If you take the dash off you will see the unit. Defender Td5 Commercial 2002
Range Rover L322 TDV8 Westminster 2012
Discovery 4 SDV6 Landmark 2016
Post #589351 2nd Jan 2017 12:16am
grafty99
Just a quick one which should tell you if you have a broken or rubbed through wire - do you get two horn blasts when you arm the alarm? If you do then it is a trigger wire fault somewhere if you don't then it is AS10 or beyond Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #589352 2nd Jan 2017 12:23am
01rwilkinson
Hi and thanks will have a look at weekend come to think about it I sometimes get two blasts of the horn
When I press key fob usually it is or I thought it was ! Because a door was not shut properly.
Thanks I will have another check round.
Post #589955 3rd Jan 2017 11:06pm
