![]() | Home > Puma (Tdci) > Clunk Free Gear Change |
defender9 Member Since: 12 Mar 2016 Location: Fylde Coast Posts: 1629 ![]() ![]() ![]() |
Interesting post Tim. I have a 15 plate Puma, when did the 16MY actually start and can you tell from looking externally which drive shafts you have?
Thanks John |
Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 925 ![]() ![]() ![]() |
You can tell the model year through the VIN plate after the usual SALL.... your VIN will then give two letters before the last set of 6 numbers so DA189345 or EA097395 or FA873026 It is this that gives the year:
2012 - CA 2013 - DA 2014 - EA 2015 - FA 2015 - GA 2016 - HA The rear drive flanges referred to go from the separate one from the shaft which have the rubber cap on the end. To an all in one flange and shaft. |
Thanks Devon-Rover, looking at the V5 mine is GA so 15MY. I will have a look at the drive shafts tomorrow to confirm.
