Home > Puma (Tdci) > TDCi dash removal tips.. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17328 |
Not difficult, just time-consuming.
1) Disconnect battery (not essential but highly advisable) 2) Remove radio 3) Remove centre dash panel 4) Remove steering wheel, column shroud, and stalk switches 5) Remove IPAC 6) Remove dash It takes under an hour and you'll then have something that looks like this (note this image is a LHD vehicle but RHD is similar): Click image to enlarge Putting back is essentially the reverse of the removal procedure. Last edited by blackwolf on 24th Nov 2016 2:16pm. Edited 1 time in total |
24th Nov 2016 11:27am |
Rashers Member Since: 21 Jun 2015 Location: Norfolk Posts: 3480 |
And if you have bits left over when you have finished, you got it wrong
24th Nov 2016 2:03pm |
gabe3105 Member Since: 25 May 2015 Location: Grimsby Posts: 237 |
^^^^ not necessarily....I always have bits left over when I re-assemble something. It just means I managed to put it back together more efficiently
24th Nov 2016 2:20pm |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4198 |
If you download the factory workshop manual, there is a very detailed step by step process for taking the dash out. 2007 110 TDCi Station Wagon XS
24th Nov 2016 6:30pm |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10378 |
If you're ever thinking of fitting heated mirrors, that would be a good stage to do it.
I fitted aircon to a puma a few years back and fitted heated mirrors too. The best way to route the wires |
24th Nov 2016 6:56pm |
rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1296 |
AArrgh its that picture again ! I always come over a bit queasy when I see the 'dash-removed ' photo. Stuff of nightmares
24th Nov 2016 7:49pm |
Rossy, not the same picture. But similar nevertheless.
Eric Click image to enlarge You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
24th Nov 2016 7:56pm |
Where's my medication when I need it !!
24th Nov 2016 7:58pm |
24th Nov 2016 8:03pm |
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 |
Think he might need something stronger
24th Nov 2016 8:08pm |
strang Member Since: 16 May 2012 Location: Happy Valley Posts: 1380 |
Said Mr Haynes! Euro-Leafing to infinity and beyond..... |
24th Nov 2016 8:11pm |
Thanks chaps, good info. 👌
Is it drivable once you hook up the instruments and wheel again? I don't have a full day to play with it, and could chip away at tasks on my lunch etc. Solved the bowel problem, working on the consonants... |
24th Nov 2016 8:47pm |
http://www.greatbigstuff.com/products/aspirin Click image to enlarge Solved the bowel problem, working on the consonants... |
24th Nov 2016 8:52pm |
Well, I suppose it could be drivable without a dash, but you'll have the IPAC flapping about and all the switchgear flopping about (assuming you put the switches back in). It would be wierd but possible, I think, but I'm not sure it's a good idea. |
24th Nov 2016 10:42pm |
