Home > Puma (Tdci) > TDCi dash removal tips..
agentmulder
Kuwait
I'd like to find a leak, check corrosion on the internals of my bulkhead, chase a stereo connection issue and replace an air-con cable.
Anyone got a 'how to' remove the dash?
I'd like to get pretty deep in there and can likely figure it out, but any tips on stuff that requires a bit of force, easiest order etc. would be greatly appreciated. Solved the bowel problem, working on the consonants...
Post #580075 24th Nov 2016 11:22am
Not difficult, just time-consuming.
1) Disconnect battery (not essential but highly advisable)
2) Remove radio
3) Remove centre dash panel
4) Remove steering wheel, column shroud, and stalk switches
5) Remove IPAC
6) Remove dash
It takes under an hour and you'll then have something that looks like this (note this image is a LHD vehicle but RHD is similar):
Putting back is essentially the reverse of the removal procedure.
Post #580084 24th Nov 2016 12:27pm
Rashers
And if you have bits left over when you have finished, you got it wrong Very Happy
Post #580107 24th Nov 2016 3:03pm
gabe3105
^^^^ not necessarily....I always have bits left over when I re-assemble something. It just means I managed to put it back together more efficiently Laughing
Post #580109 24th Nov 2016 3:20pm
Bluest
If you download the factory workshop manual, there is a very detailed step by step process for taking the dash out. 2007 110 TDCi Station Wagon XS
Post #580161 24th Nov 2016 7:30pm
If you're ever thinking of fitting heated mirrors, that would be a good stage to do it.
I fitted aircon to a puma a few years back and fitted heated mirrors too. The best way to route the wires Thumbs Up
Post #580169 24th Nov 2016 7:56pm
rossy
AArrgh its that picture again ! I always come over a bit queasy when I see the 'dash-removed ' photo. Stuff of nightmares Shocked
Post #580179 24th Nov 2016 8:49pm
ericvv
Post #580181 24th Nov 2016 8:56pm
rossy
Where's my medication when I need it !! Big Cry
Post #580183 24th Nov 2016 8:58pm
ericvv
Post #580186 24th Nov 2016 9:03pm
williamthedog
Think he might need something stronger Rolling with laughter
Post #580192 24th Nov 2016 9:08pm
strang
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Galway Green
Said Mr Haynes! Euro-Leafing to infinity and beyond.....
Post #580195 24th Nov 2016 9:11pm
agentmulder
Kuwait
Thanks chaps, good info. 👌
Is it drivable once you hook up the instruments and wheel again?
I don't have a full day to play with it, and could chip away at tasks on my lunch etc. Solved the bowel problem, working on the consonants...
Post #580219 24th Nov 2016 9:47pm
agentmulder
Kuwait
ericvv wrote:
Thumbs Up
http://www.greatbigstuff.com/products/aspirin
Post #580222 24th Nov 2016 9:52pm
Well, I suppose it could be drivable without a dash, but you'll have the IPAC flapping about and all the switchgear flopping about (assuming you put the switches back in). It would be wierd but possible, I think, but I'm not sure it's a good idea.
Post #580270 24th Nov 2016 11:42pm
