![]() | Home > Tdi > Discovery 200TDI what bits will fit 200TDI 90 |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2706 ![]() ![]() |
Gearbox - shift position can be sorted with an adaptor and your old shift housing, however as you say the input shaft is the wrong length for a 200Tdi Defender.
Transfer box - will fit more or less, but likely to be a different ratio. I put a Discovery/RRC handbrake in my 90 a while back, which helps with comfort and ease of use. |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8172 ![]() ![]() ![]() |
tbox will be 1.2 on disco, 1.4 on pre puma defenders 1.2 on puma defenders
handbrake lever handbrake drum engine gbox with a few changes front axle rear axle calipers radius arms trailing arm seats rims Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
