Home > Tdi > Discovery 200TDI what bits will fit 200TDI 90
LANDROVER
I bought a 200 TDI Discovery for the engine to put in my Series 2.
When I break it is there anything that will fit my 90?
I guess the gear box is no good as it has short shift lever & I believe incorrect input shaft length?
Will the Transfer box fit?
My axles on the 90 are different so they won't be no use to me except 10 spline diffs to up gearing of series if I want.
Is there anything I should salvage before I sell the bits that I dont use on the Series conversion?
Thanks. Thumbs Up
Post #579259 20th Nov 2016 7:24pm
Retroanaconda
Gearbox - shift position can be sorted with an adaptor and your old shift housing, however as you say the input shaft is the wrong length for a 200Tdi Defender.
Transfer box - will fit more or less, but likely to be a different ratio.
I put a Discovery/RRC handbrake in my 90 a while back, which helps with comfort and ease of use.
Post #579297 20th Nov 2016 9:26pm
jst
tbox will be 1.2 on disco, 1.4 on pre puma defenders 1.2 on puma defenders
handbrake lever
handbrake drum
engine
gbox with a few changes
front axle
rear axle
calipers
radius arms
trailing arm
seats
rims Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #579416 21st Nov 2016 12:46pm
