Home > Maintenance & Modifications > Td5 dash into 200tdi
RobKeay
I am in the process of installing a td5 dash to my 200tdi. Couple of things has any done this and has some tips. Also does anyone know where to get the plugs for the back of the switches??
Post #57546 7th Feb 2011 8:44pm
jst
i have a td5 bulkhead and dash into a 200tdi. most of the info you need is on lr4x4.com - check the wibbly wobbly speedo thread. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #57557 7th Feb 2011 9:20pm
RobKeay
Been looking on there! Have you got the digital speedo??
Post #57560 7th Feb 2011 9:26pm
jst
yes, what do you need to know?
i have the wiring diagrams somewhere. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #57567 7th Feb 2011 9:31pm
RobKeay
Was about to buy the convertor for the gearbox but it said 300tdi on wards so was abut worried. How did you sort the centre bit such as the hazard light switch??
Post #57571 7th Feb 2011 9:36pm
jst
by converter you mean the module that goes in the T box? it will work on any model. i would check you can get the old clamp off and the existing speedo cable out first though, easiest to access from the top.
i just extended the wires from the side of the steering wheel and then wired to suit the new plug. you need the diagram for it? i may have that too. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #57573 7th Feb 2011 9:38pm
RobKeay
A diagram for that would be great help. Speedo is out already I've got the link from lr4x4 about how to fit that seems pretty straight forward. Having a big push at min I've been rebuilding it for five years now think it's time I finished.
Post #57578 7th Feb 2011 9:45pm
jst
well, just looked and i can't find it. if i dont have it that means i managed to make it work without one, which therefore makes me think the wires use the same colour codes for the old and new ones and i just extended and joined them on. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #57822 8th Feb 2011 9:14pm
RobKeay
No worries will have to just get on with it. Most things seem to be just falling into place.
Post #57878 8th Feb 2011 11:26pm
