Home > Maintenance & Modifications > Td5 dash into 200tdi |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8150 |
i have a td5 bulkhead and dash into a 200tdi. most of the info you need is on lr4x4.com - check the wibbly wobbly speedo thread. Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
7th Feb 2011 9:20pm |
RobKeay Member Since: 19 Jul 2009 Location: Stafford Posts: 1588 |
Been looking on there! Have you got the digital speedo??
7th Feb 2011 9:26pm |
yes, what do you need to know?
i have the wiring diagrams somewhere. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
7th Feb 2011 9:31pm |
Was about to buy the convertor for the gearbox but it said 300tdi on wards so was abut worried. How did you sort the centre bit such as the hazard light switch??
7th Feb 2011 9:36pm |
by converter you mean the module that goes in the T box? it will work on any model. i would check you can get the old clamp off and the existing speedo cable out first though, easiest to access from the top.
i just extended the wires from the side of the steering wheel and then wired to suit the new plug. you need the diagram for it? i may have that too. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
7th Feb 2011 9:38pm |
A diagram for that would be great help. Speedo is out already I've got the link from lr4x4 about how to fit that seems pretty straight forward. Having a big push at min I've been rebuilding it for five years now think it's time I finished.
7th Feb 2011 9:45pm |
well, just looked and i can't find it. if i dont have it that means i managed to make it work without one, which therefore makes me think the wires use the same colour codes for the old and new ones and i just extended and joined them on. Cheers
8th Feb 2011 9:14pm |
No worries will have to just get on with it. Most things seem to be just falling into place.
8th Feb 2011 11:26pm |
