Home > Maintenance & Modifications > Front bumper mounted tow ball?
WarPig
i fancy getting one of those front bumper mounted towballs that hook over the bumper temporarily. Anyone know where sells them, and if they are recommended?
I know I could get a steering guard with receiver hitch, but a front bumper mounted ball could be positioned offset so I can see down the side of the caravan when pulling it out of the barn where its stored, before hitching up properly. I dont want to drill two holes in my front bumper and bolt a towball to it, I really want one that can be easily removed.
Post #224062 2nd Apr 2013 10:21am
leeds
Think it is Devon 4x4 do a slip over bumper tow ball mount.
Yes it is Bearmach BA3107 on this page
Whilst a 2" receiver is normally mounted central on a steering guard it is possible to get them offset by a maximum of about 8" or 200mm to one side
Brendan
Post #224068 2nd Apr 2013 10:56am
WarPig
Thanks Brendan, Ive just searched the Bearmach part and that looks ideal Thumbs Up
Post #224071 2nd Apr 2013 11:04am
ChrisCM
United Kingdom 2010 Defender 110 Puma 2.4 SW Santorini Black
Very old post I know Confused but does anyone have any experience of using one of the BA3107 removable towball brackets? I fancy one for use with my Bak Rak removable winch bracket.
Chris 2010 Defender 110 Station Wagon, Santorini Black.
Post #578494 17th Nov 2016 5:41pm
Cupboard
Unless you're only using a small winch (which will be fine) bear in mind that winch bumpers are a lot heavier duty than the standard ones. You're liable to banana a normal bumper if you load up a 9,000lbs winch on one.
Post #578538 17th Nov 2016 8:51pm
ChrisCM
Hi Cupboard,
I agree with you, I was thinking of using it off centre, over the chassis leg so that the mounting didn't do what you suggest and banana the bumper. But will it fit either side of the chassis leg mounting? looks like it's designed to do that. Can any users advise?
Post #578634 18th Nov 2016 9:56am
DAZ110
Think it usually goes each side of the chassis rail.
But I wondered if it would still fit if your Defender has A/C as the grill sticks out further and might stop it from fitting over the top of the bumper?
Here is the one sold by Simmonites:
http://www.simmonites.com/shop/vehicle-acc...tow-hitch/
Post #578717 18th Nov 2016 2:27pm
ChrisCM
Daz110,
Good point, I'll have a look see.
Post #578725 18th Nov 2016 2:54pm
DAZ110
Also very close to the number plate by the looks of it ?
Post #578748 18th Nov 2016 4:37pm
ChrisCM
I may have to remove the grill to put it on, but if it's black I can leave it on there semi-permanently. I don't think it will affect the number plate.
Post #578761 18th Nov 2016 5:38pm
DAZ110
Chris, let us know how you get on. Thumbs Up
Post #578789 18th Nov 2016 7:16pm
