Home > Technical > Weather and alarms
Lew-M
England 2012 Defender 90 Puma 2.2 HT Keswick Green
Weather and alarms
Hi everyone,
We had a couple of extremely heavy downpours last night of rain/hail, needless to say the landy didn't like it and the intensity of the downpours set tripped the ultrasonic sensor inside the cab, setting the alarm off. So I'm probably not the most popular neighbour today as I happened twice. Has anyone else experienced this ever and what (if anything) can be done? I'm guessing the sound of the rain/hail on the roof has been that loud that it tripped it?
Cheers,
Lewis
Post #578373 17th Nov 2016 8:24am
Martyn668
Happened to me too this morning. It was chucking it down. Don't remember it ever happening before. I've had a trapped moth set it off though.
Post #578491 17th Nov 2016 5:24pm
mrd1990
Wales 2000 Defender 110 Td5 CSW Epsom Green
Are you sure its the ultrasonic sensor?
More likely than not, its the bonnet sensor. The metal bracket that holds it in place can bend or the switch can become damaged/worn out. All it takes is the vibration of heavy rain hitting the bonnet and it sets it off Thumbs Up
Post #578496 17th Nov 2016 5:53pm
Mjibex
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Loire Blue
Re: Weather and alarms
Lew-M wrote:
Hi everyone,
Cheers,
Lewis
Do you get rain water in the passenger footwell?
Regards
Mark.
Post #578580 17th Nov 2016 10:23pm
Lew-M
No water no, I used to have that leak but managed to sort it a while back!
Cheers,
Lew
Post #578582 17th Nov 2016 10:25pm
01rwilkinson
England 2001 Defender 90 Td5 HT Rutland Red
Hi there I have the same problem, bad weather ,hail ,hard rain . sometimes
If I forget to disarm alarm,jet wash sets her off .
I will occasionally sneak up on her and bang on the side !
Just to see if she's awake ,you know strange lot handymen!
Almost makes you feel good to be alive strange!!!😁
Post #580638 26th Nov 2016 6:28pm
Doc P
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Firenze Red
Sub-zero temps this week, and with the car not driven for 2 days she started first time of asking but the alarm sounded transiently.
Following this, I get a notification from Skytag that the battery had been disconnected.
I take it this was because of battery power being briefly completely drained from all other systems to supply the starter motor to turn over a (very cold) engine?
Is it an early sign of an ageing battery (only 3 years old though) or something or nothing?
Post #581566 30th Nov 2016 10:51am
