Home > Puma (Tdci) > Ashcroft MT82 Output shaft kit - step by step guide?
agentmulder
Kuwait
Gidday all,
I'm noticing not so much noise, but the feel of backlash when coasting and backing on and off the accelerator (the sound of backlash greatly reduced when I did my halfshafts/CV recently).
I know it could be the diff or props (which I will get to eventually) but it 'feels' gearboxish to me. Anyways, I'm looking at the Ashcroft MT82 Output shaft kit:
http://www.ashcroft-transmissions.co.uk/mt...t-kit.html
Interested to hear your stories in installing one and how much it improved the feel (let alone improved a complete failure!). I've never gone into the gearbox or transfer, what don't I know ? Solved the bowel problem, working on the consonants...
Post #578091 16th Nov 2016 6:28am
This may help: http://www.defender2.net/forum/topic41494....croft+mt82 Darren
Post #578095 16th Nov 2016 6:48am
LR90XS2011
had my shaft replaced under warranty but am looking to fit this kit if and when the play starts to come back DEFENDER 90 TDCI XS,
Post #578096 16th Nov 2016 6:49am
agentmulder
Kuwait
Ohhh Censored - WTF, how'd I miss that ! Neutral
OK, off to read Thumbs Up Solved the bowel problem, working on the consonants...
Post #578104 16th Nov 2016 7:28am
agentmulder
Kuwait
Ok, read all that.
Interesting info, especially regarding how to tell if you're likely fretting (the red dust telltale).
Perhaps this thread can be resurrected by being a request for a step by step/'how to' install? Solved the bowel problem, working on the consonants...
Post #578114 16th Nov 2016 8:01am
Okan
Switzerland 2009 Defender 110 Puma 2.4 SW Stornoway Grey
Hi all,
After the failure of my transfert box at 115000km I replaced it with a new Transfert box from ashcroft with sleeve casing and ATB inside, I altough replaced the clutch who was making some rattle because of a little spring going out, and finally I installed the ashcroft output shaft system. The old one was very dry probably installed without any grease. I will let you know about this setup, but what I can tell you is that it totaly supressed the horrible "Klong" noise when I was changing a gear. The only thing I can hear now is a little continuous noise of whistling, but I'm not sure if it comes from the transmission or maybe it's just my turbo that I didn't hear before that anymore.
Best regards
Post #578142 16th Nov 2016 10:05am
TopQ1967
Netherlands 2012 Defender 130 Puma 2.2 HCPU Buckingham Blue
Hi Okan,
My gearbox went after 153.000 last weekend. Just looking at the options available.
I saw Ascroft's what is meant by a sleeved casing (I saw that on the options list too)?
Best regards
Post #578165 16th Nov 2016 12:43pm
TopQ1967
Double post, sorry.
Post #578166 16th Nov 2016 12:48pm
Td5
Finland 1996 Defender 90 300 Tdi CSW Coniston Green
Hi, You chaged CV-joints & half shafts?
In my 07 90 was the rear half shaft splines quite worn. Same with all drive shaft flange splines.
I changed rear half shafts and all drive flanges. Also I installed the Ashcroft output shaft kit.
Perhaps I should check the pinion back lash.
I think the Puma clutch is more on/off than 300Tdi. Actually I like th 300Tdi 90 Defender much
more than the Puma. Somehow there is more character in the 300Tdi. Brgds,
Juha
'96 300Tdi 90
'07 Puma 90
Post #578193 16th Nov 2016 2:24pm
ashtrans
Site Sponsor
TopQ1967 wrote:
Hi Okan,
Best regards
See :
Linkhttp://www.ashcroft-transmissions.co.uk/di...asing.html Dave
Post #578274 16th Nov 2016 7:22pm
