Home > Technical > Tow bar bolt sizes
Andyred90
Tow bar bolt sizes
Hi, I removed my td5 towbar to repaint and have safely stored the bolts to reattach it!
Does anybody have the sizes of the bolts that are used as I will be quicker to buy new than to look for the old ones!
Post #577423 12th Nov 2016 11:37pm
taffrican
Wales 2002 Defender 90 Td5 HT Java Black
Not knowing what type of tow bar you have fitted it will be difficult to say for sure, but they will either be M12 or M16 and should be about 50-75mm in length Thumbs Up Optimists say the glass is half full..
Pessimists say the glass is half empty..
Engineers say the glass is twice the size it needs to be!
Post #577428 13th Nov 2016 12:38am
miker
M16 for a standard tow ball, minimum of 8.8 grade, probably 50mm in length. Personally I'd use washers under nut and bolts and nylocs nuts
Post #577431 13th Nov 2016 12:59am
Andyred90
Hi tow bar is a genuine LR version on a td5 90
Post #577433 13th Nov 2016 1:02am
Screbble
As Miker, mine are M16 X 50.
High tensile.
Cheap enough and plenty on eBay.
Post #577434 13th Nov 2016 1:02am
RED-DOT
Halfords sell them too. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #577616 13th Nov 2016 10:17pm
I'm guessing that the OP is talking about bolting the tow bar to the chassis rather than the tow ball. Darren
Post #577650 13th Nov 2016 10:53pm
Andyred90
Bolts
Correct it's the connections to the chassis I need.
Three bolts that go into the underside of the cross member
Two bolts that go through the front face of the cross member
Two bolts that fix the stays onto each of the chassis rails.
Post #577663 13th Nov 2016 11:32pm
miker
In that case, have a look here!
http://new.lrcat.com/#!/1228/6454/6455/597/6727
Post #577665 13th Nov 2016 11:38pm
Andyred90
Perfect, Thanks
Post #577670 13th Nov 2016 11:54pm
