Home > Technical > Tow bar bolt sizes |
taffrican Member Since: 14 Jan 2011 Location: Living room Posts: 624 |
Not knowing what type of tow bar you have fitted it will be difficult to say for sure, but they will either be M12 or M16 and should be about 50-75mm in length Optimists say the glass is half full..
Pessimists say the glass is half empty.. Engineers say the glass is twice the size it needs to be! |
12th Nov 2016 11:38pm |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1763 |
M16 for a standard tow ball, minimum of 8.8 grade, probably 50mm in length. Personally I'd use washers under nut and bolts and nylocs nuts
12th Nov 2016 11:59pm |
Andyred90 Member Since: 30 Mar 2013 Location: Wantage Posts: 482 |
Hi tow bar is a genuine LR version on a td5 90
13th Nov 2016 12:02am |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2102 |
As Miker, mine are M16 X 50.
High tensile. Cheap enough and plenty on eBay. |
RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363 |
Halfords sell them too. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
13th Nov 2016 9:17pm |
I'm guessing that the OP is talking about bolting the tow bar to the chassis rather than the tow ball. Darren
13th Nov 2016 9:53pm |
Correct it's the connections to the chassis I need.
Three bolts that go into the underside of the cross member Two bolts that go through the front face of the cross member Two bolts that fix the stays onto each of the chassis rails. |
13th Nov 2016 10:32pm |
In that case, have a look here!
http://new.lrcat.com/#!/1228/6454/6455/597/6727 |
13th Nov 2016 10:38pm |
Perfect, Thanks
13th Nov 2016 10:54pm |
