![]() | Home > Maintenance & Modifications > Under-door seals |
LR029309 - DOOR WEATHERSTRIP LOWER FRONT DEFENDER late 2010 onwards i stand corrected
![]() ![]() Last edited by dorsetsmith on 12th Nov 2016 10:24am. Edited 2 times in total |
Lew-M Member Since: 04 Apr 2016 Location: North West Posts: 95 ![]() ![]() ![]() |
Thanks very much! Should these be on the doors already or were they an option?
if not fitted to the door the only option is fit one
they were fitted from late 2010 onwards, before 2010, they were the same as the TD5's
Mine is 2012, but doesn't appear to have them, but it is a county "farmer spex" maybe missing on these?
this one good read on the lower door seal
http://www.defender2.net/forum/topic6370-45.html |
I have a poverty spec 2011 that has them. Been through bonnet deep water (I wouldn't have gone through if I'd realised) and been the only person with a dry interior. I did have to laugh at the usually smug Toyota owners ![]() |
itolond Member Since: 16 Jan 2016 Location: Singapore Posts: 193 ![]() ![]() ![]() |
can these be retro fitted to earlier 90's defenders?
Stiff1 Member Since: 09 Dec 2014 Location: Cornwall Posts: 601 ![]() ![]() ![]() |
I remember a thread on here where a member retro fitted them.
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 749 ![]() ![]() ![]() |
I have a 2011 D110 SW and the seals are still the old type. Rubber strips with foam rubber cubes at the ends. I'm actually planning to "upgrade" to the newer seals once the coin presents itself as they are a bit expensive if shipped here to where I'm currently assigned.
Hi all,
so if am reading correctly there should be no huge issue beyond a fiddle to get these retro fitted to a 97 Def, is the a rear door version as well? (S/W) i am removing the doors for a complete overhaul and thought this would be best to do at the same time |
I believe it is not so straight forward on an older model as the shape of the door changed at some point and it is this later profile that readily accepts the newer door seal.
Link found. http://www.defender2.net/forum/topic6370.h...p;start=45 |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6638 ![]() ![]() ![]() |
Those with the fabricated frame doors probably can't have them added as the bottom of the door is a sharp corner rather than the radius these are designed to fit. ![]() ![]() |
yes my door profile is the square welded type - what are the alternatives?
