![]() | Home > Maintenance & Modifications > Headlinings for hardtops |
Hello folks,
Has anybody got any suggestions for buying or making a headlining for a vehicle without Alpine windows? My 90 has side windows but no Alpines and, as such, only has a (very tatty) headlining over the front seats. ![]() Click image to enlarge I notice that LaSalle offer one (or used to - there website is two years out of date) but it's not cheap! Years ago, I covered the roof of a Series III hardtop with carpet tiles, which was effective but needed a lot of glue! This time, I'm looking for something that can accommodate acoustic foam behind, so that approach won't work. Also, I must admit that this is all a bit tentative - I fully intended to convert to soft top in the spring, but I'm wavering a bit as it's just so useful as is ![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
I've covered the inside of my roof with 2mm sound deadening then 8mm (I think) foil backed closed cell foam. It noticeably reduces the condensation but you can still see the roof supporting ribs.
Yeah, that'd be essentially my plan too, but it's what to finish it with that's the dilemma. Darren
Thanks. That may yet be the easiest solution. I guess I'm hoping that someone will point me at some clever way of making a simple headlining
![]() In fact, the more I think about it, if I use a standard part at the front the shape for the rear is really quite simple. Perhaps some sort of plastic sheet that can be heat formed to get the curves on each side? I'll have to think about this a bit more... Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
So that was my plan too - I have two sheets of PVC foamboard cut to the correct size.
They're just sat in my garage though ![]() |
Landy-Novice Member Since: 23 Jun 2013 Location: wiltshire Posts: 118 ![]() ![]() |
I had same issue so this was my answer. All sound proof of course. 👍 Puma headlighing and stretchy carpeted ply.
Edit. Just realised you got Windows.lol So unless you cut it out and I filled the gap all the way round the ply, it wouldn't be ideal for you. ![]() Click image to enlarge |
Heh, heh, yeah thanks. I'd still like to be able to see out
![]() As an aside, it looks like yours, like mine, is suffering from being painted pink in a previous life ![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Thanks but have already seen that. Was really looking for cheaper and/or DIY alternatives. Darren
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2316 ![]() ![]() ![]() |
I have a LaSalle headlining and as a long term solution is worth every penny in my opinion.
