![]() | Home > My Defender > Thought's for my Defender |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17569 ![]() ![]() ![]() |
I have never had any issues with them at all, wet or dry. They are not the quietest, but then the Defender isn't a quiet envorinment. They are not as noisy as Goodyear Xtra-Grips! |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3791 ![]() ![]() |
I use the std Conti 235's
Cheap as chips as most people seem to change them? not sure why as I use mine on the road 99.9% of the time and they perform very well for a big truck. Wet or Dry I've had no issues? no mega tyre noise you can get going wide and the side wall is huge so no worries if the wife uses your truck (did I type that...) |
AJC Member Since: 30 Nov 2015 Location: Lancashire Posts: 1366 ![]() ![]() |
I run KO's on 285/75/16's with 0 offset 16x8 modulars, not as nice to drive as the 235/85's that were on prior but still good, no suspension modification either
Tom-Bodenham Member Since: 08 Nov 2016 Location: Bradford Posts: 7 ![]() ![]() ![]() |
Ahh I see. Suppose they all have their pros & cons, I wont be buying anything until the new year so I have time to see for the best deals around for them.
Cheers for all the help though guys! |
Swac3 Member Since: 21 Feb 2015 Location: Aberdeen Posts: 363 ![]() |
And as I cant resist on these kind of threads, Bear in mind your rim width just cos they fit doesn't mean they're right.
Pays your money and makes your choice, most likely never going to be an issue unless you're arguing your case in a courtroom or with your insurer. 3 Landrovers |
