Home > Puma (Tdci) > Oil spray
diffbeer
Oil spray
I noticed a oil sprayed up on the underside of the bonnet left hand side, left wingtop and a large patch on my driveway.
Puma 2007 ,had its first service a week ago
Any suggestions of what it could be ?. I checked the caps -they are tight
Post #5761 26th Dec 2008 7:45pm
Eduardo
Re: Oil spray
Hi Diffbeer
Probably brake vacuum pump.
Several of us had the same problem.
Regards Eduardo
Post #5762 26th Dec 2008 8:16pm
MK
^^^^^^^what he said
Post #5782 27th Dec 2008 2:57pm
diffbeer
SPOT ON EDUARDO et all !
Vacuum pump , landrover assist recovered my Puma . Ready to collect today Thumbs Up
Post #5800 30th Dec 2008 10:15am
Petrovich
Russia
Technical Service Bulletin
No.LTB00177
09 October 2008
Subject/Concern: Brake Vacuum Pump Seal Oil Leak
Models:
Defender (LD) 2.4L Diesel Only
2.4L Diesel Only VIN-range: 7A732615 Onwards
Markets: All
Section: 206-07
Summary:
Oil leaking from the brake vacuum pump front oil seal.
Cause: Dirt ingress into the pump pulley seal resulting in damage to the lip and subsequent oil leakage (the new brake vacuum pump has a secondary dirt lip seal). Suggested Customer Concern Code - R31.
Action: Should a customer express concern, install a new brake vacuum pump (refer to Global Technical Reference GTR Workshop Manual, section 206-07 (70.15.19)).
Parts Required:
Description Part Number Quantity
Brake vacuum pump LR012183 1
Gasket LR004381 1
Labour Time:
Operation Description Operation No. Time
Install a new brake vacuum pump 70.15.19 0.7 hours
Repair/Claim Coding:
Causal Part: LR012183
ACES Condition Code: 42 Defender 110 '07
Post #5822 1st Jan 2009 11:08am
