![]() | Home > Technical > What type of seatbelt is in the Puma? (Roll cage legality) |
Thon Member Since: 22 Nov 2015 Location: Salisbury Plain Posts: 696 ![]() ![]() |
I would say that Defender front belts are web-clamp retractor lap and diagonal (3 point).
4 point tend to be used in competition vehicles as the entry level option. |
agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324 ![]() ![]() |
Apparently there are two types: those that 'retract under load' and 'stop you sooner', and those that don't.
Which I'm told is nothing to do with the 'pull on it fast and it stops - pull on it slow and it doesn't' functionality. Still not sure what type are in a Defender, or if the people I'm talking to are talking out of their bums. Technical bureaucracy at its finest ![]() |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1853 ![]() ![]() ![]() |
Defender has basic lap and diagonal three point clamp under load type.
The other sort you refer to have an explosive charge normally on the buckle, linked to the airbag system that tightens the belt during impact. Audi used a mechanical version 20 odd years ago called procon ten or similar that used steel cables and pulleys rigged around the superstructure that pulled the belts tighter as the car crumpled. I think you can get a three point harness where the third central point at the back is on a retractor reel so in a crash or roll over you are safely in but in normal driving you would be able to reach the handbrake and high low change lever. Keith |
So I'm hearing I need to use the '900mm' measurement yeah? Solved the bowel problem, working on the consonants...
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17731 ![]() ![]() ![]() |
Google is your friend:
So a "web clamp pretensioner" belt is one incorporating what is generally known as a Supplementary Restraint System or SRS, and you do not have one in your Defender. |
