Home > Puma (Tdci) > HELP.. Oil all over the place!
G4sweep
Germany 2012 Defender 110 Puma 2.2 XS CSW Santorini Black
Good Evening,
Walking past my 110 on the way in from work whilst giving it a carress i noticed oil on top of the left wing and running down the left headlight surround, upon opening the bonnet (although i cant see much as its dark), there is oil over left hand side of engine. I have been under the poor beast and can also see oil over the engine block and oil stains on the axle.I have checked the dipstick level and its where it was the other week when i checked. Could it be a gasket? or something more serious?
Anyone any similar experiences? Big Cry
Cheers Sweep Sweep
2.2 110 XS SW
Gone;
08 D3 XS
BN55 WPV G4 4.4V8 D3.
O7 G4 Mongolian Recce 110 USW
Post #57455 7th Feb 2011 6:00pm
Glynparry25
There was a problem with some part that basically sprayed oil everywhere.... can't remember what it is now as no-one has had a problem with it for a while.
Glyn Dog Sheep
Post #57458 7th Feb 2011 6:18pm
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
Vacum pump for the brakes or the seals on the brake servo Original Member Pie n Pea Club.
110 HCPU Tipper
Post #57459 7th Feb 2011 6:20pm
BigMike
Check the turbo pipes and end clips
edit to ask - you mean the left side as you stand at the front of the vehicle and look at the engine?
Post #57460 7th Feb 2011 6:20pm
Glynparry25
That is the badger Thumbs Up
Glyn Dog Sheep
Post #57461 7th Feb 2011 6:20pm
willy eckerslike
http://www.defender2.net/forum/topic3182.html?highlight=brakes Original Member Pie n Pea Club.
110 HCPU Tipper
Post #57463 7th Feb 2011 6:21pm
G4sweep
Cheers Glyn, Mike & Willy Thumbs Up
I'm running through the search facility on the forum to try and find something similar.
Sweep Sweep
2.2 110 XS SW
Gone;
08 D3 XS
Post #57464 7th Feb 2011 6:21pm
willy eckerslike
New type have three seals old type only had two I think. Should have been done by now. Original Member Pie n Pea Club.
110 HCPU Tipper
Post #57466 7th Feb 2011 6:22pm
The Boy
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Rimini Red
Vacuum pump is oil fead and it may be th seal gone. My first Puma did it and it sprayed oil all over the engine bay.
Post #57467 7th Feb 2011 6:22pm
G4sweep
Cheers The Boy, and Glyn, Mike & Willy. Ive had a look and the photos in the link and they look similar to what i can see on my 110. I'll get it into the stealers ASAP. I believe my beast had all the recall work done before i bought it, infact its had alot replaced when it came back from mongolia after the 09 G4 challenge recce. The 110 drives alright, is it safe to drive it to the stealers? Mine is 3 months outside its warranty but i do have AA breakdown repair cover, so hoping it will get sorted under that.
Cheers Thumbs Up
Mike, the left hand side of the engine(passenger side) Thumbs Up Sweep
2.2 110 XS SW
Gone;
08 D3 XS
Post #57479 7th Feb 2011 6:40pm
K9F
My vacuum pump went too! Sprayed oil all over the bonnet!! Swapped out under warranty well documented on here and many fellow forum members with similar experiences! Welcome to the club! Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #57481 7th Feb 2011 6:44pm
BBSJK
England 1998 Defender 90 V8 Petrol 50th Auto Atlantis Blue
Following a forced steam clean of the engine bay a couple of weeks ago I'd say it was the vacuum pump!
JK No the other left . . .
Post #57482 7th Feb 2011 6:44pm
G4sweep
Mega!! I see this is a common problem then? My 110 has been faultless, it was only the other week i thought how lucky i was..... after reading some of the dramas/problems some people have. Oh how wrong.
How many eyeballs/limbs will the stealers want if its not covered under my AA breakdown cover/parts and labour policy?
Bow down Cheers for the quick replies guys it sure has put my mind at ease, not nice seeing oil all over the place.
Bloody Landrovers Sad Sweep
2.2 110 XS SW
Gone;
08 D3 XS
Post #57486 7th Feb 2011 6:50pm
mse
Glyn Dog Sheep
Thumbs Up Thumbs Up Mike
Post #57524 7th Feb 2011 8:09pm
Zagato
It's like some sort of right of passage when something goes wrong with your Landy! If it makes you feel any better I was reading a thread on Jap 4x4's last week on a sailing forum and all the problems/breakdowns/poor quality interiors and components Shocked There's a que for their ceremonial breakdown christenings Laughing
Post #57550 7th Feb 2011 8:53pm
