Home > Puma (Tdci) > HELP.. Oil all over the place! |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 |
There was a problem with some part that basically sprayed oil everywhere.... can't remember what it is now as no-one has had a problem with it for a while.
Glyn |
7th Feb 2011 7:18pm |
willy eckerslike Member Since: 15 Jun 2009 Location: North yorks Posts: 1789 |
Vacum pump for the brakes or the seals on the brake servo Original Member Pie n Pea Club.
110 HCPU Tipper |
7th Feb 2011 7:20pm |
BigMike Member Since: 13 Jul 2010 Location: Lancashire Posts: 2253 |
Check the turbo pipes and end clips
edit to ask - you mean the left side as you stand at the front of the vehicle and look at the engine? Last edited by BigMike on 7th Feb 2011 7:22pm. Edited 1 time in total |
That is the badger Glyn |
http://www.defender2.net/forum/topic3182.html?highlight=brakes Original Member Pie n Pea Club.
110 HCPU Tipper |
7th Feb 2011 7:21pm |
G4sweep Member Since: 24 Sep 2010 Location: Paderborn Posts: 182 |
Cheers Glyn, Mike & Willy
I'm running through the search facility on the forum to try and find something similar. Sweep Sweep 2.2 110 XS SW ---------------------------- Gone; 08 D3 XS BN55 WPV G4 4.4V8 D3. O7 G4 Mongolian Recce 110 USW Last edited by G4sweep on 7th Feb 2011 7:23pm. Edited 1 time in total |
New type have three seals old type only had two I think. Should have been done by now. Original Member Pie n Pea Club.
110 HCPU Tipper |
7th Feb 2011 7:22pm |
The Boy Member Since: 28 Aug 2008 Location: East Northants Posts: 1459 |
Vacuum pump is oil fead and it may be th seal gone. My first Puma did it and it sprayed oil all over the engine bay.
Cheers The Boy, and Glyn, Mike & Willy. Ive had a look and the photos in the link and they look similar to what i can see on my 110. I'll get it into the stealers ASAP. I believe my beast had all the recall work done before i bought it, infact its had alot replaced when it came back from mongolia after the 09 G4 challenge recce. The 110 drives alright, is it safe to drive it to the stealers? Mine is 3 months outside its warranty but i do have AA breakdown repair cover, so hoping it will get sorted under that.
Cheers Mike, the left hand side of the engine(passenger side) Sweep 2.2 110 XS SW ---------------------------- Gone; 08 D3 XS BN55 WPV G4 4.4V8 D3. O7 G4 Mongolian Recce 110 USW |
7th Feb 2011 7:40pm |
My vacuum pump went too! Sprayed oil all over the bonnet!! Swapped out under warranty well documented on here and many fellow forum members with similar experiences! Welcome to the club! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
7th Feb 2011 7:44pm |
BBSJK Member Since: 12 Sep 2009 Location: Ledbury, Herefs Posts: 100 |
Following a forced steam clean of the engine bay a couple of weeks ago I'd say it was the vacuum pump!
JK No the other left . . . |
Mega!! I see this is a common problem then? My 110 has been faultless, it was only the other week i thought how lucky i was..... after reading some of the dramas/problems some people have. Oh how wrong.
How many eyeballs/limbs will the stealers want if its not covered under my AA breakdown cover/parts and labour policy? Cheers for the quick replies guys it sure has put my mind at ease, not nice seeing oil all over the place. Bloody Landrovers Sweep 2.2 110 XS SW ---------------------------- Gone; 08 D3 XS BN55 WPV G4 4.4V8 D3. O7 G4 Mongolian Recce 110 USW |
7th Feb 2011 7:50pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5034 |
Mike |
7th Feb 2011 9:09pm |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5006 |
It's like some sort of right of passage when something goes wrong with your Landy! If it makes you feel any better I was reading a thread on Jap 4x4's last week on a sailing forum and all the problems/breakdowns/poor quality interiors and components There's a que for their ceremonial breakdown christenings |
7th Feb 2011 9:53pm |
