![]() | Home > In Car Electronics > Replace Fog Light Switch Puma |
BuckBlu110 Member Since: 19 Apr 2014 Location: in the pub Posts: 719 ![]() ![]() ![]() |
Should be able to pull it right out and unplug it, if you use something to prize it out be careful not to ping the face off, then you will have to either have to pull the fascia off or remove the radio and push from behind.
Best way I found to prize it out is a small flat headed screw driver and lever from the sides, not the top or bottom. Be sure to put something soft between the dash and the screwdriver so it doesn't mark the dash. That should lift it out enough so you can pull it out with your fingers. |
