Home > In Car Electronics > Replace Fog Light Switch Puma
AdamGT3
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Corris Grey
Hi
Do you have to take the centre console out to replace a switch in the Puma or can you pull the witch all the way out?
Thanks
Adam
Post #574377 30th Oct 2016 4:03pm
BuckBlu110
United Kingdom 1994 Defender 110 BMW M57 3.0 Diesel CSW Buckingham Blue
Should be able to pull it right out and unplug it, if you use something to prize it out be careful not to ping the face off, then you will have to either have to pull the fascia off or remove the radio and push from behind.
Best way I found to prize it out is a small flat headed screw driver and lever from the sides, not the top or bottom. Be sure to put something soft between the dash and the screwdriver so it doesn't mark the dash. That should lift it out enough so you can pull it out with your fingers.
Post #574392 30th Oct 2016 5:03pm
