Home > Puma (Tdci) > Engine Cutting Out - Glow-Plug & Oil pressure light
Page 3 of 3 <123
HardCharger
Hi 100inch,
Where does one find the main power relay? I've posted that I've had this momentary cut off issue and am scheduled to change out the VCV, can't hurt, right? But I'd like to check the main power relay as well.
Thanks!
Post #573445 26th Oct 2016 3:04am
Falcon
New Zealand 2010 Defender 90 Puma 2.4 SW Indus Silver
So could anyone point me to the main relay? Neutral
Post #573711 27th Oct 2016 6:31am
HardCharger
Just to update everyone, had the VCV changed and ran very well for two weeks before the problem presented itself again. After some head scratching, we decided to replace the main relay and check the main earth point. Upon checking the battery, it seems that the negative connection was still bit loose despite it rocking the truck when you check but apparently if you move it side to side, there is a bit of play so loosened it then pushed down hard on the connection then re-tightened. All good. Truck running like a champ now much more quiet and stronger. I was also advised to go with V-Power diesel as it's a better Euro 4 fuel compared to Fuel Save?
Post #581009 28th Nov 2016 2:57am
I put this together to carry for reference in my 2007 Puma. It might be of use.
https://www.defender2.net/gallery/albums/u...Relays.pdf
Post #581033 28th Nov 2016 8:55am
HardCharger
Hi blackwolf!
These will come in handy! Will print and add to my growing reference collection for my truck! Thumbs Up One thing, what happened to the identification of numbers 10 to 23? Smile
Post #581233 29th Nov 2016 1:42am
I was only interested in relays!
Post #583603 8th Dec 2016 10:57pm
HardCharger
Hi blackwolf,
Fair enough! Still a valuable resource.
Many thanks again!
Post #583624 9th Dec 2016 1:46am
Falcon
If anyone stumbles across this in the future, check the battery connections. Mine were loose
Post #609281 14th Mar 2017 5:40am
100inch
Australia 2010 Defender 110 Puma 2.4 CSW Santorini Black
HardCharger wrote:
Hi 100inch,
Thanks!
Sorry for the delay getting back! Yes it is one of the grey ones. I have all my electrics moved in the cubby box and could easily feel how hot it got. Hope yours is running fine by now. m
Post #609369 14th Mar 2017 12:34pm
Woodbutcher
France
I know I'm resurrecting on old post but I've now got the same problem with my 2010 110.
Happening more often now and always seems to be when changing up into 3rd gear soon after starting ,hot or cold and within the first mile or so but at random times.
I've checked the battery connections and they're solid an a rock, I'll order a new stater relay tomorrow and keep my fingers crossed but there are no Landy specialists around this part of France and I've no access to any diagnostic gear.
I've got a couple of long distance drives coming up and the last thing I need is to be stranded with the other half and two dogs in the middle of nowhere.
Any other things I could look out for?
Thanks in anticipation.
Pete
Post #632076 18th Jun 2017 11:55am
BarneyRubble
England 2010 Defender 90 Puma 2.4 HT Stornoway Grey
Check the under seat relay connections are all tight.
That's what the problem was with mine. Barney
D4 - 2016 Graphite, Montalcino Red
Written Off - 2010 90 Hard Top, Stornoway Grey
Post #632077 18th Jun 2017 12:14pm
Woodbutcher
France
Thanks for that Barney,
Had the seat up this morning and gave everything a good wiggle, all seemed ok but I'll replace the relays just in case.
It's a real PITA when you can't pinpoint the problem and you don't know when it's going to happen again.
I've only had the 110 since last September, it was the previous owners pride and joy always garaged and no mods or alterations but a new business venture meant that he needed some cash. I'd previously had a 2007 puma 90 and not a days trouble with it but that went back to the UK with the ex.
Pete
Post #632084 18th Jun 2017 1:50pm
HardCharger
Asides from replacing the VCV and the main relay, check that the earth on the battery is tight and making contact with the clamp. In my case, while changing out the VCV and the main relay helped make the truck run smoothly, it was eventually the contact between the earth post on the battery and the clamp that was the culprit. I had to make a conical copper sleeve to make the contact good. It went well after that. But alas, due to this, my battery wore down and I had to replace it with a new one. Either that or it's been running the same battery since 2011 and just got changed out a few months ago... Whistle
In any case, I hope this helps.
Post #632174 19th Jun 2017 6:04am
Page 3 of 3 <123
