Home > Td5 > Rear mud flaps
mustafasoleiman
United Kingdom 2003 Defender 90 Td5 XS CSW Indus Silver
Rear mud flaps
How are the rear mud flaps attached to the body?
It looks like my right one is attached only at the top left corner and the right corner is hanging loose...
Alex
Post #573433 25th Oct 2016 10:33pm
agentmulder
Kuwait
Guessing a 90 or you'd simply compare sides ??? (I drive 110 where it's symmetrical) Solved the bowel problem, working on the consonants...
Post #573440 25th Oct 2016 11:32pm
lightning
His profile says 2003 90 TD5 XS.
The rear mud flaps are attached to the underside of the crossmember with three bolts which go into captive nuts.
If the crossmember has corroded (very common at the corners where the mud flaps are) the captive nuts can fall out, causing the mud flaps to come loose and hang by the inner bolts only.
Post #573452 26th Oct 2016 7:02am
mustafasoleiman
Thank you for all your help... I am wondering what would happen if I remove all four mud flaps?
Alex
Post #576225 8th Nov 2016 12:10pm
miker
Lots of spray. Removing fronts would lead to a horrendous amount of spray up the sides. Rears less of an issue for you, just others that cop it. I really need to put my rears back on....
Post #576281 8th Nov 2016 4:08pm
roel
I don't have any mudflap, I loose them off-road anyway. And I doubt mudflaps help to keep my 90 clean. Twisted Evil
 Roel
2003 90 Td5 (2009-now)
Post #577038 11th Nov 2016 8:18am
Rogeo1983
2010 Defender 90 Puma 2.4 CSW Zambezi Silver
The rear mudflaps are held in by captive rivnuts. Bit of a pig to replace and you need a rivnut gun. Pretty cheap.
Pm me if you want any further help with it
Post #580017 24th Nov 2016 1:13am
