Home > Maintenance & Modifications > Loose striker
Daisy90
United Kingdom 2001 Defender 90 Td5 SW Alveston Red
Loose striker
Hi all,
The bonnett striker/Spring thing has come loose, which is allowing the bonnet to float up n down a bit too much,
It appears it has a nut inside the closed off bonnet section ? But that is just spinning around, and I can't see a way of holding/ wedging it so I can tighten it all up again ?
Any clues folks ?
I don't really want to fit aero catches or bonnett pins if I can help it
Thanks again n advance
Post #571082 15th Oct 2016 6:33pm
Daisy90
Any clues folks ?
Post #571218 16th Oct 2016 1:06pm
dorsetsmith
look at the top of the striker it is thread !
may be backing nut worked loss or thread insert broken loss ?
Post #571225 16th Oct 2016 1:43pm
mk1collector
Pull down on the striker and tighten as you would a bolt. Even if the retaining plate has broken free, if you tighten slowly I should think it will catch and tighten the striker. Ray
My build thread
Post #571240 16th Oct 2016 2:42pm
Daisy90
Thanks chaps,
Yep , I think the nut / plate inside the bonnet section is loose or un attached , I'll try pulling down whilst turning it,
Failing that I did think about trying to drill two holes on the inner bonnet but line up with the inner nut / plate, then try n put two tack welds on it ?
What ya thoughts on that ?
Post #571309 16th Oct 2016 6:50pm
mk1collector
A bit risky as it has to line up with the striker plate at the bottom Ray
My build thread
Post #571397 16th Oct 2016 9:27pm
