Home > Puma (Tdci) > Is it worth cleaning my EGR? |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 |
Yes!
They are straight forward to clean, you can unclip the top of the motor housing, strip it and grease it up, There is nothing scary inside, only a motor and gears. A good dose of brake cleaner in and around the valve assembly, should see it all working again. Plug it back in, without actually fitting it first, just to make sure it works. I done mine last year and it's been fine ever since 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
16th Oct 2016 7:19pm |
