Home > Maintenance & Modifications > Pick up into convertible? |
SailingTom Member Since: 19 Nov 2013 Location: ESSEX Posts: 1722 |
Not hard at all, all you need is a spanner and the bits. Have a search as a fair few on here have done it. Myself included,
As yours is a pickup with side tabs all you'll need to buy is; hood with rope lashings, frame with door surrounds, suitable screen rail. You can swap it over in a day and selling your truck cab should at least pay for the hood. Defender puma dormobile camper |
16th Oct 2016 9:28am |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 |
The lads at Stonelake have done one
Click image to enlarge |
16th Oct 2016 5:31pm |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
I think the biggest problem is buying all the parts. Changing it is a piece of cake. I made from a pick-up a Hard Top.
Click image to enlarge Click image to enlarge Click image to enlarge Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
16th Oct 2016 7:19pm |
L90DNY Member Since: 09 Feb 2016 Location: Somerset Posts: 117 |
I thought about doing it but as it's not garaged, I decided against doing a soft top for the safety point of view and converting to a hard top instead.
When I was looking at the soft top options I found everything was available from exmoor trim for around a grand. http://www.exmoortrim.co.uk/our-models/def...l?cat=5896 http://www.exmoortrim.co.uk/90-inch-defend...-2321.html Have fun with the build! |
25th Oct 2016 12:51pm |
pjb Member Since: 08 Apr 2009 Location: Sunny Oxford Posts: 1244 |
As Tom has said very easy.
Here is my build http://www.defender2.net/forum/topic43443.html I made mine more complicated by doing bulkhead removal etc at the same time. Nice winter project 2020 P300 HSE |
25th Oct 2016 12:57pm |
mobilesawmiller Member Since: 03 Mar 2013 Location: Co,Tyrone Posts: 100 |
Have wanted a soft top for a long time. Converted my 2007 pickup. Took about 3 hours to do and the hardest part was breaking the seal on top of the windscreen - amazing what you can do with a length of 3" by 3" and a high lift jack.
Click image to enlarge Click image to enlarge Click image to enlarge |
29th Oct 2016 4:33pm |
