Home > Wheels & Tyres > Heavy Duty Steel Wheels (Wolf)
Page 16 of 16 <123 ... 141516
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
Do your britpart wheels have manufacturer stamps around the middle between the wheel nuts holes? If they do they are probably made by same OEM as the genuine ones.
From what I have seen the Tuff Torque ones are unstamped.
Post #567960 1st Oct 2016 8:25am
Arierep
Portugal 1995 Defender 90 300 Tdi SW Alpine White
No, no stamps on mine.
I got them at a killer deal, black primed. Got them painted with high end heat resistant paint and still were cheaper than originals by a very wide margin.
Was a little afraid that I got flimsy copies but calmed down once compared with an original. Even weight the same.
They were easy to balance and are keeping pressure nicely
Post #567962 1st Oct 2016 8:33am
Retroanaconda
Genuine ones are stamped with the part number, tubed/tubeless, offset, size/width, and Dunlop logo.
Post #568057 1st Oct 2016 7:59pm
BigWheels
Hello DorsetSmith, great post.
My Defender uses modulars at present with cheap spacers, bolts too short for my garage's liking.
Would authentic Wolves take 255 85 tyres and give a better turning circle without spacers?
Also if they are heavier than modulars, I assume they would absorb more bumps and shocks? Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #571004 15th Oct 2016 12:30pm
CarMan
I now have a spare set of genuine Wolfs to repaint cream/white to match the Puma roof. 4x wheels are in really good shape but silver so I'm assuming a paint shop can simply spray them, but the spare is in more of a mess so would it need bead blasting or similar first? Rob
1993 200tdi 90 hard-top
1998 300tdi 90 soft-top
Post #573526 26th Oct 2016 1:51pm
Cupboard
Wolfs take 255/85s no issue. Turning circle depends on the offset of your current wheels, and if you don't know what the offset is then you can measure it. Once you know the offset of what you've got, add in the spacers and compare that to the offset of the Wolf.
Wheels being heavier increase the unsprung weight which should make the ride, handling and acceleration slightly worse. Give it's a fairly heavy tyre I have no idea how much you'd actually notice and the unsprung weight on a Defender is pretty massive anyway.
Post #573712 27th Oct 2016 7:46am
Cupboard
Sorry to bump this thread, but it seems like the most relevant place to put this information and I couldn't find it anywhere else.
I've just got my Wolf wheels back from being shotblasted and primed and decided to weight them, and to compare that to the weight of my standard steel wheels.
ANR4583, genuine Wolf with no tyre, 15.2kg
Standard steel with new 7.50R16 Michelin Latitude, 28kg
Weight of tyre (I have a good condition one not mounted) 17kg
Calculated weight of standard wheel, 11kg
So the Wolf is 4kg per corner heavier.
I'd love to know what the Boost alloy weighs, according to one source I've found it's 12.2kg, according to another it's 11-11.5kg.
Post #659778 26th Oct 2017 5:54pm
UtilityTruck
You only have to look at the gauge (thickness) of steel used in the wolfs to know they are a heavy wheel! That brings advantages and disadvantages Razz 2014 Keswick Utility 2.2
Post #659797 26th Oct 2017 7:51pm
I'll have a full set for sale soon, with tyres with less than 1800 miles on them...only ever been wet once.
Post #659812 26th Oct 2017 9:11pm
JOW240725
What offset are Wolf wheels? Can you get with different offsets? James
Instagram @suffolk_rovers
Post #659824 26th Oct 2017 9:40pm
+20.6mm
No.
Post #659833 26th Oct 2017 10:21pm
JOW240725
Thank you 😊 James
Post #659842 27th Oct 2017 6:08am
L90Andy
United Kingdom 1997 Defender 90 300 Tdi ST Nato Green
Raptor 4x4 do 'Wolf' style wheels but with an ET0 offset, so will stick out 20mm wider than genuine ones.
http://www.raptor4x4.co.uk/raptor-4x4-wolf...-et-0.html
However they are still only 6.5J so wouldn't take anything more than a 255 width tyre.
Still, 255/85R16 on those could be a real nice setup and no need for spacers Cool Instagram: L90andy
My 1984 Ninety: http://www.defender2.net/forum/topic56071.html - SOLD!
My 2015 Defender: http://www.defender2.net/forum/topic39625.html - SOLD!
Post #659860 27th Oct 2017 10:36am
