Home > Td5 > TD5 110 mid cross member bolts M8 x20?
DC101
United Kingdom 2003 Defender 110 Td5 DCPU Epsom Green
Hi,
I need to loosen the mid cross member on my 110 to (finally) patch some repairs to the seat box.
As I suspect I'll have to grind off the nuts, am I correct that they are M8 x 20 flange bolts/nuts?
Many thanks.
Post #570747 13th Oct 2016 9:41pm
marsie
England 2010 Defender 110 Puma 2.4 XS CSW Galway Green
I use m8x20 on chassis swaps on most mountings. Buy them 5000 at a time Mr. Green
Paul 2000 90 TD5,galv chassis, d2 axles ,Bas remap , alisport intercooler , d2 transfer box , side windows-more to come-much more!! *GONE*
2004 110 TD5 Double cab. *GONE*
2010 110 2.4 XS station wagon
Post #571917 18th Oct 2016 8:35pm
DC101
Thanks Paul,
I looked on line and it stated M8 flanged nuts/bolts.
However, none I have just taken off my mid crossmember were flanged....
Does it matter so long as washers are in place?
Would using nylocs be a good idea, or just go with spring washers?
Cheers,
Rob
Post #571922 18th Oct 2016 8:43pm
marsie
I just use conventional zinc plated bolts. Washer both sides and always use nylocs Thumbs Up 2000 90 TD5,galv chassis, d2 axles ,Bas remap , alisport intercooler , d2 transfer box , side windows-more to come-much more!! *GONE*
Post #571935 18th Oct 2016 8:59pm
DC101
Just about to replace my fixings on this. Should you use any anti-sieze with Nylocs such as copper grease, and any thoughts on torque? Does copper slip affect torquing?
I've done an internet search, and much conflicting opinion.
Many thanks
Post #572427 21st Oct 2016 6:29am
marsie
It certainly wouldn't hurt. Always grateful of copper grease when you need to remove that part in 5 years time Thumbs Up 2000 90 TD5,galv chassis, d2 axles ,Bas remap , alisport intercooler , d2 transfer box , side windows-more to come-much more!! *GONE*
Post #572510 21st Oct 2016 3:05pm
