Home > In Car Electronics > Urgent- broken down - Now Fixed, photo with fault... |
Grenadier Member Since: 23 Jul 2014 Location: The foot of Mont Blanc... Posts: 5878 |
That's why I love this forum. Even though it's yet to be fixed, the answers and options coming through aplenty, leave me to believe it will. And no doubt you guys are in the middle of heart bypass surgery, planning world domination or live making and still have the time to help the Grenadier stuck in a Godforsaken service station in Bonneville. Legends you all. Have decamped to Mac-doh and will report back. Ta . Monsieur Le Grenadier
I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
12th Oct 2016 11:04am |
I've been banging like a fury. The last time I banged with such vigour, well, I'll save you the details.... Monsieur Le Grenadier I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
12th Oct 2016 11:06am |
jrule Member Since: 10 Aug 2015 Location: Hertfordshire Posts: 302 |
perhaps an issue with immobiliser? otherwise sounds like a battery/starter issue
12th Oct 2016 11:14am |
Hi jrule, not sure about the immobiliser as the little red flashing lights on the dash have gone as well. Also, I never use it, as I have a separate immobiliser/key set up. Still on manual unlock. Monsieur Le Grenadier
12th Oct 2016 11:20am |
Maybe try disconnecting the battery completely for few minutes and then reconnecting
12th Oct 2016 11:22am |
Not wishing to sound like a complete moron, but it's been twenty years since I had a (potential) flat battery, but can I still jump start it and expect it to run given the engine size, plus associated electronics? I know my fiat uno could do so, but this I'm not sure. I'd have to get 50kms to safety at my local Def garage.....any advice before I track down a grizzly Romanian trucker? Monsieur Le Grenadier
Shouldn't have an issue jump starting just make sure that jump leads are up to the task and you have a good connection to the terminals
12th Oct 2016 11:29am |
mk1collector Member Since: 17 Sep 2009 Location: West Yorkshire Posts: 6772 |
Starter motor stuck? Roll it for ward a few times in gear and then try starting it. Ray
12th Oct 2016 12:19pm |
When it started this morning, no problems. Didn't feel sticky. Still think electrics. Monsieur Le Grenadier
12th Oct 2016 12:23pm |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7908 |
Hope you get it sorted soon! Can't help unfortunately but please do let us know what the problem is for future reference. James
12th Oct 2016 12:33pm |
Just you can jump start it but make sure you leave a battery connected to it at all times.
If your battery had completely conked out then you might need to disconnect it to jump it, but then reconnect it before you take the jump leads off. |
12th Oct 2016 1:23pm |
Fixed. Need to get a move on, will send strep this evening Monsieur Le Grenadier
12th Oct 2016 1:40pm |
Wild Card 90 Member Since: 03 Dec 2014 Location: Gerlingen Posts: 1060 |
Gren, sorry to hear of your plight! In view of the influence slamming the flappy Defender door previously had on proceedings, I'd suggest you check for a loose relay or fuse, under the dash and in the right hand seat box. Between the hamburger and your milkshake, that is. Good luck! 1998 Tdi 90 SW,
2008 Td4 90 SW, 2012 2.2 90 SW, 2" raised Trailmaster/Terrafirma Heavy Track Raids, 255 MTīs, Recaro CSīs, anorak, wellingtons |
12th Oct 2016 2:22pm |
Thank you all once again. Below is the photo of the culprit. Found in the battery box, a fuse between two wires, one (the yellow connection you can see) on the negative terminal, the other end, well frankly I can't remember I was so happy getting it fixed. That little blighter shut the whole car down. Any ideas what it's for? Immobiliser as someone pointed out?
Click image to enlarge And thank you all once again. As the yanks would say 'awesome' response. Genuinely brilliant and allowed me to fix it DIY, no call out, no charges (being on the M-Way). What's more, I know what to look for next time, above and beyond this fuse. You're gentlemen one and all... Monsieur Le Grenadier I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
12th Oct 2016 4:54pm |
