Home > In Car Electronics > Urgent- broken down - Now Fixed, photo with fault...
Page 2 of 3 <123>
Grenadier
That's why I love this forum. Even though it's yet to be fixed, the answers and options coming through aplenty, leave me to believe it will. And no doubt you guys are in the middle of heart bypass surgery, planning world domination or live making and still have the time to help the Grenadier stuck in a Godforsaken service station in Bonneville. Legends you all. Have decamped to Mac-doh and will report back. Ta . Thumbs Up Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #570275 12th Oct 2016 11:04am
Grenadier
couplands wrote:
^^^ In that case, slam the door few more times..Wink
cheers
simon
I've been banging like a fury. The last time I banged with such vigour, well, I'll save you the details.... Whistle Monsieur Le Grenadier
Post #570277 12th Oct 2016 11:06am
jrule
United Kingdom 2000 Defender 90 Td5 CSW Oslo Blue
perhaps an issue with immobiliser? otherwise sounds like a battery/starter issue
Post #570282 12th Oct 2016 11:14am
Grenadier
Hi jrule, not sure about the immobiliser as the little red flashing lights on the dash have gone as well. Also, I never use it, as I have a separate immobiliser/key set up. Still on manual unlock. Whistle Monsieur Le Grenadier
Post #570285 12th Oct 2016 11:20am
jrule
Maybe try disconnecting the battery completely for few minutes and then reconnecting
Post #570287 12th Oct 2016 11:22am
Grenadier
Not wishing to sound like a complete moron, but it's been twenty years since I had a (potential) flat battery, but can I still jump start it and expect it to run given the engine size, plus associated electronics? I know my fiat uno could do so, but this I'm not sure. I'd have to get 50kms to safety at my local Def garage.....any advice before I track down a grizzly Romanian trucker? Monsieur Le Grenadier
Post #570289 12th Oct 2016 11:22am
dorsetsmith
Whirly90 wrote:
Usually along the passenger side of the vehicle going from the inside of the chassis rail on to a suitable bolt on the engine, usually around the sump area. The gearbox one will be the same, from the chassis to a suitable bolt on the gearbox
Earth also from the chassis to the body work right hand side A pliers underneath
Post #570292 12th Oct 2016 11:26am
jrule
Shouldn't have an issue jump starting just make sure that jump leads are up to the task and you have a good connection to the terminals
Post #570294 12th Oct 2016 11:29am
mk1collector
Starter motor stuck? Roll it for ward a few times in gear and then try starting it. Ray
My build thread
Post #570314 12th Oct 2016 12:19pm
Grenadier
When it started this morning, no problems. Didn't feel sticky. Still think electrics. Monsieur Le Grenadier
Post #570315 12th Oct 2016 12:23pm
JOW240725
Hope you get it sorted soon! Can't help unfortunately but please do let us know what the problem is for future reference. James
Instagram @suffolk_rovers
Post #570319 12th Oct 2016 12:33pm
Cupboard
Just you can jump start it but make sure you leave a battery connected to it at all times.
If your battery had completely conked out then you might need to disconnect it to jump it, but then reconnect it before you take the jump leads off.
Post #570338 12th Oct 2016 1:23pm
Grenadier
Fixed. Need to get a move on, will send strep this evening Monsieur Le Grenadier
Post #570343 12th Oct 2016 1:40pm
Wild Card 90
England 2012 Defender 90 Puma 2.2 SW Indus Silver
Gren, sorry to hear of your plight! In view of the influence slamming the flappy Defender door previously had on proceedings, I'd suggest you check for a loose relay or fuse, under the dash and in the right hand seat box. Between the hamburger and your milkshake, that is. Good luck! 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
2" raised Trailmaster/Terrafirma
Heavy Track Raids, 255 MTīs,
Recaro CSīs, anorak, wellingtons
Post #570352 12th Oct 2016 2:22pm
Grenadier
Thank you all once again. Below is the photo of the culprit. Found in the battery box, a fuse between two wires, one (the yellow connection you can see) on the negative terminal, the other end, well frankly I can't remember I was so happy getting it fixed. That little blighter shut the whole car down. Any ideas what it's for? Immobiliser as someone pointed out?
And thank you all once again. As the yanks would say 'awesome' response. Genuinely brilliant and allowed me to fix it DIY, no call out, no charges (being on the M-Way). What's more, I know what to look for next time, above and beyond this fuse. You're gentlemen one and all... Bow down Monsieur Le Grenadier
Post #570397 12th Oct 2016 4:54pm
Page 2 of 3 <123>
