Home > Td5 > Experimenting with a heater air scoop - numpty question
party monkey
England 2005 Defender 110 Td5 XS CSW Cairns Blue
Folks,
The heater in my '05 Td5 is pretty good.... Nothing fantastic but capable.
I've read so many threads on various forums on the pros/cons of a heater air scoop that I decided to get one and just see if there was any noticeable difference.
It's a dead easy fix and no problems there but I have a rather silly question.........
Should you replace the existing plastic wing top grille, or should you simply stick the scoop over the top of the existing? Embarassed
My logic was to stick over existing given that ...
1) The scoop fits snugly over the existing grill, like it's meant to be so.
2) The scoop does have a grille but I thought it perhaps better to have both scoop grille and old grille in place to minimise the amount of crap that could be collected going into the heater
3) The existing grille has what I can only describe as some 'baffles' built into it, which I guess help with directing/regulating air flow.
All that said though, please correct me if that is not the right way to do it......
Cheers Jon - 110 td5 [sold]. Currently Defenderless.
Post #56999 5th Feb 2011 8:21pm
Zinke
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
I would say its designed to replace the original one but if it fits nicely over the original one and looks good then just fit it over the top, it will stop leafs being sucked up and getting stuck in your heater matrix.
Pete.
Post #57004 5th Feb 2011 8:37pm
T1G UP
leve the originl on as you'll need that in there when you have to grab ll the leaves out of the scoop
Post #57014 5th Feb 2011 9:01pm
Glynparry25
Another reason why to leave the origional in........ You won't loose it!! Don't you hate it when you try to put something back to origional and you can't remember where you put the part Rolling Eyes
Glyn Dog Sheep
Post #57015 5th Feb 2011 9:05pm
party monkey
Thanks folks... over the top it is....
Should have had the courage of my convictions on that one but very much appreciate the sense check Thumbs Up Jon - 110 td5 [sold]. Currently Defenderless.
Post #57019 5th Feb 2011 9:53pm
party monkey
Scoop fitted.... Would have liked to have counter sunk the screws but the thickness of the plastic prevented it... will teach me to buy tat off ebay I guess Confused
So now the next question...... 1 scoop or 2 ?
Second scoop just for cosmetics of course....
What you reckon ??? Jon - 110 td5 [sold]. Currently Defenderless.
Post #57070 6th Feb 2011 9:24am
K9F
I had the same dilemma when fitting the KBX Scoops! As one who suffers from a slight case of OCD I would propose two to maintain the balance and asymmetry! By removing the blanking plate and fitting the second it would also give more cooling airflow to your engine compartment! If you go through life with your head in the sand....all people will see is an ar5e!!
Post #57089 6th Feb 2011 10:35am
mse
I left the 2nd off as it also allows more cooling air to the enigne, water into the engine and other debris. Mike
Post #57150 6th Feb 2011 3:04pm
T1G UP
one IMO.
Post #57158 6th Feb 2011 3:52pm
alanhid
Scotland 2006 Defender 90 Td5 XS CSW Bonatti Grey
So whats the verdict....do you notice any difference to the heater? Life is not a rehearsal!
Def 90td5 CSW xs 2006
Post #57207 6th Feb 2011 6:07pm
party monkey
Haven't tried it yet. Will report back tomorrow after work journeys.
And I'm being swayed to just leaving it at one.
Thanks all for input Thumbs Up Jon - 110 td5 [sold]. Currently Defenderless.
Post #57213 6th Feb 2011 6:40pm
Laurie
Would be interesting to see a Defender in a windtunnel to see how the air flows over the wings.
Post #57231 6th Feb 2011 7:40pm
party monkey
Pleased to report that there was an improvement in the flow of air into the cab. It's not a massive improvement but certainly one that warrants keeping the scoop. What's most pleasing is that the improvement was felt from 30mph upwards, so you don't have to drive like a loon to get the benefit. Jon - 110 td5 [sold]. Currently Defenderless.
Post #57339 7th Feb 2011 11:12am
ickle
Hi Laurie - have you or anyone else seen the effect of a brick in a wind tunnel? Rolling with laughter
On a dry day, sellotape loads of 2" bits of wool all around the area you want to test, then drive along with someone else videoing the results - real basic DIY wind tunnelling used in the 60s/70s for tuning cars.....
Lets us know how (if) you get on with it!
Post #57396 7th Feb 2011 2:27pm
TC
Good point, when you drive off with standing water on the vehicle, it doesn't so much blow back toward the screen as straight up onto the top of the screen toward the roof. I suspect the nose creates such a level of turbulence that air just lifts directly at the top of the cab missing out the wingtops all together!
Post #57409 7th Feb 2011 3:26pm
