Home > Maintenance & Modifications > 110 mud flaps
Page 3 of 3 <123
ROBBONTHEROCK
Scotland 2007 Defender 110 Puma 2.4 XS CSW Firenze Red
Hi All,
See photos below, i already repaired this with an ali strip, but looks like it just voted through.
IS the stainless brackets still available?
2001 TD5 so not too bad i think Smile
Andy
Post #569527 8th Oct 2016 5:22pm
ericvv
^^ Yes. stainless mudflap holders for the rear of a 110 are available from Offroad-Tec. I have those installed, a very good product. Below the link to the product and a picture of how they look on mine. If, like I, you would have the Entreq reinforcement brackets already installed, you probably can leave those in place and bolt the Offroad-Tec mudflap holders right on to those reinforcement brackets. Thumbs Up
Eric
http://offroad-tec.de/shop/main_bigware_34...cName=body
 You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #569530 8th Oct 2016 5:37pm
ROBBONTHEROCK
Thanks for that, but was wondering about the repair bracket.
Is panel repair sections available anywhere?
Andy
Post #569550 8th Oct 2016 8:01pm
ericvv
Post #569582 9th Oct 2016 4:53am
Retroanaconda
Just repair again with a better piece of aluminium.
Or spend £80 on some bits of metal, your call Laughing
Post #569598 9th Oct 2016 8:32am
To repair that, you really need a length of reasonably thick Ali angle - say 25mm x 25mm. Secure it to the inside edge of the wing with Sikaflex or similar and drill a new mounting hole.
To stop it happening again, isolate the bracket from the wing with some rubber washers on the bolt, either side of the ali. This will allow a bit of flexibility and prevent the vibrations from wearing out the mounting point. Darren
Post #569599 9th Oct 2016 8:32am
Oops, double post. Darren
Post #569600 9th Oct 2016 8:32am
Page 3 of 3 <123
