Home > Maintenance & Modifications > 110 mud flaps
Page 2 of 3 <123>
Not got a photo but I did put penny/repair washers on the other side of the bracket - there're actually a size too big as they stick out from the wing edge slightly; but I wanted to ensure a large clamping area as the slot cut in the bracket is actually quite large.
I did also toy with using some plastic bolts & nuts so that these would shear before just ripping off a larger section of wing but thought in the end that might be too weak.
Post #230342 25th Apr 2013 6:06am
I did a very similar repair on mine to Supacat's, however I bonded the aluminium angle to the panel with a flexible adhesive to ensure that the load was spread over a larger area. Worked like a dream.
Unfortunately the flap on the other side then came off and was lost, at which time I decided that the mudflaps are functionally useless appendages anyway so I took the first one off as well. 40k miles later I wonder why I didn't just take them off in the first place!
Post #230369 25th Apr 2013 8:31am
WarPig
Ive been running without mine for a few years now, but I need to fit them again as my caravan gets sprayed with dirt without them. I'll use some ali as per supacats post Thumbs Up
Post #230374 25th Apr 2013 9:12am
geobloke
After 4 years without mudflaps on the 110 I refitted mine last weekend and the difference in the appearance of the whole truck has changed. I like... Mr. Green I am very tempted with the modified front Entreq brackets.
Also last night I spring cleaned the entire chassis and under carriage back to the waxoyl. I could not believe how much dirt came out of those hard to reach places. I am hoping replacing the mud flaps is going to reduce the build up of crud a little.
Post #230388 25th Apr 2013 10:19am
leeds
We have these in stock
Made from stainless but come with two 'isolators' to separate stainless reinforcing brackets from ali wing plus anti seize/corrosion paste.
Remember stainless and ali can react and stainless can cold weld itself.
Brendan
PS Edited to add we also have rear stainless mud flap brackets for a 110 but not powder coated
Post #230402 25th Apr 2013 11:17am
smb
United Kingdom 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
Geobloke,
Are those spots under your Fairlead?
SMB
Post #230410 25th Apr 2013 11:38am
geobloke
smb wrote:
Geobloke,
SMB
Yes, there are 4 spots and 2 fog lights under the bumper. The problem with the type of bumper I have is that there is nowhere to mount spots and without a roof rack you can't put them up high. So this is my solution. They work very well too.
Post #230449 25th Apr 2013 1:41pm
You do know that if those spots have their centres 600mm (a metric 2') from the ground or less, then you can only legally use them in fog or falling snow?
Under UK law any light with its centre 600mm or less from the ground is a fog light and can only be used thus, unless it is an original factory fitment on a Euro-type-approved vehicle, in which case it would be illegal under EU law for the UK to prohibit it.
Post #230459 25th Apr 2013 2:28pm
leeds
I have just been and measured the height of the bumper on our white 90. Standard bumper, factory tyres rims and suspension. I think the centre is 590mm (OK ground was uneven and no one in vehicle)
So it would look like any spots/driving lights etc fitted into a standard bumper/standard suspension etc would just be on border of legality if not below it.
If low profile tyres/lowered suspension/mounted under bumper then it looks like they would be illegal.
DRL in standard bumper etc. Do DRL come under driving lights/spot height restriction??
Brendan
Post #230634 26th Apr 2013 8:40am
Brendan
Brendan,
This is a very grey area, one which makes even towing weights etc look straightforward!
As I understand it European law allows factory-fitted DRLs and various other lights (such as the stupendously useless "turning lights") to be fitted within 600mm of the ground, and allows vehicles so fitted to pass EU type approval under either M or N classes. As such, the UK is not allowed to prohibit them. These are of course "autonomous" lights over which the driver has no control. Fog lights can of course also be fitted 600mm or less from the ground.
UK law (the Road Vehicles Lighting Regulations and the Motor Vehicles (Contruction & Use) Regulations) specifically states that lights fitted with their centres less than 600mm (originally 2') from the ground may only be used in conditions of fog or falling snow, later extended to allow "poor visbility" (such as smoke, not just darkness).
So it would certainly not be possible for the CPS to bring a successful prosecution for someone stopped in their M1 type-approved Eurobox with DRLs near the ground, nor if you had an M1 Eurobox which wasn't factory fitted but has subsequently been retro-fitted with the same system that the factory type-approved.
However if you fit a completely non-standard sub-600mm light to an M or N vehicle, ie a system which wasn't part of the type approval, or if you fit sub-600mm lights to a non Euro-type approved vehicle, then you *may* run the risk of prosecution, it all rather depends on the wording of the EU directives and the GB Statutes which implement them in this country. I think it is most likely that you are committing an offence if you use them, and as such if you have fitted sub-600mm DRLs there is a risk it will fail an MOT (if you cannot turn them off, technically the car isn't roadworthy).
In this part of Dorset the Police will stop cars which have front fog lights on when it isn't foggy, using - quite legitimately - the fog lights as justification, and then give the driver a thorough check (which I think is an excellent policy)!
So in summary I believe (but stand to be corrected) that unless your vehicle was type approved with DRLs, fog lights, or turn lights 600mm or less from the ground, then the ONLY lights you can legally use, 600mm or less from the ground are fog lights, which can inly be used in fog, falling snow, or poor visibility. So an aftermarket DRL bumper is probably technically illegal unless used in conjunction with a suspension lift.
If my interpretation is correct (and as noted in the past, I am not a lawyer) then a further question is whether it is legal to supply things like DRL bumpers if they cannot legally be used on the road. I don't see why it shouldn't be, since the supplier has no control over the use of the product, the wiring of the lights, or whether the vehicle is used on the road or not. Also, if a DRL bumper was in fact illegal, could it be argued that the vehicle is unroadworthy with the consequent impact on insurance? I don't know, very grey area!
Post #230645 26th Apr 2013 10:08am
smb
Hi Ginjez,
Please accept my apologies for asking Geobloke about his lights as I think I may have changed the subject of your thread!?!
Geobloke, I like how you have found a place to put low level spots despite the legality which I'm not bothered about as they would only be used off road to cast a shadow in ruts so I can spot them easier. It's very good that the position you have found gives a degree of protection.
Post #230652 26th Apr 2013 10:35am
Oops, sorry! Shocked
Post #230689 26th Apr 2013 12:50pm
leeds
Think of it as a pub conversation which has just progressed from the original question.
I have learnt various things from both the original topic and the spin off topic.
Brendan
Post #230697 26th Apr 2013 1:29pm
smb
Brendan,
I couldn't agree more. I have learnt more about Defenders in the last 4 months than I have done in my lifetime. And that is only from you guys(and girls).
I am only new to this. I usually hate things like this especially Facebook and another LR forum(whose members are only interested in who has the biggest and who can p Censored as the furthest) and being very new to it feel an outsider. I know a lot of you guys go back a long way.
My reason for apologising is quite simple. A similar scenario a couple of week ago where someone asked about an electrical issue. Someone else replied to find out it was for a td5 and not a puma(he had a workshop manual). I have been after a puma manual for a longtime so asked him where he got it from. He was very good and gave me the link and I thanked him. The original op got upset by this and passed a sarccy comment about him opening the thread and someone else benefiting from it. That is my reason.
I have no issue whatsoever with other people benefiting from a thread I may start and most of the time it is where it leads that is more interesting.
If it wasn't for you guys and the banter you have I would have got rid of my 110 a long time ago when I first experienced the problems. You guys with your Wealth of experience and knowledge have made what could have been a nightmare with the dealers, into a pleasurable experience.
Post #230784 26th Apr 2013 6:38pm
WarPig
Mmmm. sounds like Landyzone! Very Happy Mr. Green
Post #230815 26th Apr 2013 8:43pm
Page 2 of 3 <123>
