Home > Td5 > Td5 defender
texpis
2007 Defender 90 Puma 2.4 CSW Java Black
Td5 defender
Hi all
I am looking to buy a defender 110 2001 unfortunately it's a long way from me and looks like my option Is to train down and drive back. The only concern I have is its a 2001 with I guess the early engine with the problematic heads, the chap has no idea if the head has Been repaired. The Defender has over 100k on it. My question is would the plastic pegs holding the head still have failed by now or is it still a ticking time bomb.
Mick
Post #569086 6th Oct 2016 10:13am
bob neville
It may have the 15P engine. Mine is Sept 2001 and was one of the first with a 15P and the newer centre dash.
Have you any pictures, interior would be useful, and maybe we can see it it is a facelift or not ?
2013 Defender 90 CSW - sold
Post #569090 6th Oct 2016 10:30am
texpis
Cheers for the reply Bob its this one early 2001 I believe
http://www.ebay.co.uk/itm/Land-Rover-Defen...SwHoFXqhDs
Post #569091 6th Oct 2016 10:34am
bob neville
It says May 2001 so will be a 10P.
Looks like somebody has fitted the later centre dash.
You could ask for the engine number to be 100% sure but I don't think the 15P's came in earlier than September 2001.
Post #569106 6th Oct 2016 11:42am
kzycnn
United Kingdom 2003 Defender 110 Td5 XS CSW Oslo Blue
Are you reading the reg date as American's do, Bob? Month/day/year instead of (our) usual day/month/year? It could be a November car, in which case a 2002 model year. It is certainly an '02 face lifted dash - and air con as well, which is a bonus. Looks very tidy and, I would think, worth the journey.
Tony
Post #569110 6th Oct 2016 11:54am
bob neville
I think you are right Tony. A November reg will have the 15P and facelift dash.
Mick, get the engine number from the seller and then you will know for sure.
It does look like a tidy vehicle.
Edit. If it was a November vehicle it would be on a 51 plate - this one is a Y plate so dates it pre September. I know you can't be 100% sure with the plates so engine number is needed !
Post #569111 6th Oct 2016 11:58am
texpis
Cheers for the replies guys if it's the early engine will it have been sorted by100k miles? The air con doesn't work but I'm sure I can sort it.
Mick
Post #569115 6th Oct 2016 12:15pm
bob neville
Difficult to say. I bet there are quite a few 10P engines around still with the plastic pins. If it is a 10P and you are worried about it unfortunately the only way to find out is to take the head off and check.
Post #569116 6th Oct 2016 12:21pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Just drive it, it'll work or it won't. Part of the adventure. I bought from Germany imported to Canada and drove it 1500 miles right off the boat. 10P 2000 model. Just decided to go for it and nothing since... have fun!
Cheers 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #569144 6th Oct 2016 1:41pm
texpis
Well I've done a car check and it's a 10p engine which is prob okay I am not averse to doing a head if it goes. The other slight worry is the old MOTs says advisory GENERAL CORROSION TO REAR CHASSIS AND BODY I've asked for pics of chassis. I noticed there is a gap in the ownership of a year after that advisory so probably in a dealer just a bit worried of a bodged chassis.
What do you guys recon? Mick
Post #569150 6th Oct 2016 3:37pm
4RF RDS
Definitely get pictures of the rear frame... lots 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #569153 6th Oct 2016 4:07pm
lightning
Well, it looks alright on the photos but most of them do.
It's just passed an MOT "with no advisories" so l would guess that the "general corrosion to body and chassis" has been repaired.
It also has four new doors which is never a bad thing.
It's at the lower end of TD5 SW prices and needs a good looking over as with any older Defender.
You'll have to take a chance with the cost of a train ticket.
Post #569563 8th Oct 2016 8:57pm
texpis
Well I have had pics of the chassis and the points on the body where the paintwork isn't the best none of it is off putting, it has an all new Exmoor trim interior. So I am going down on Thursday to have a look see and buy if all is okay.
Mick
Post #569785 9th Oct 2016 8:34pm
