Home > My Defender > Daisy the Doublecab
Page 3 of 26 <123 4 ... 242526>
Stacey007
How did you fit the gauge into the dash?
Can you change the settings while in in or do you keep in on the same ones?
Easy to do?
Thanks
Post #569099 6th Oct 2016 12:10pm
Roy5695
I followed a guide on http://defender90xs.blogspot.co.uk/2014/09...ation.html
Its not hard if you're confident in our own abilities.
I have installed buttons on the side of the steering cowl that control the unit in situ so I have full functionality. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #569101 6th Oct 2016 12:21pm
Roy5695
I also created my own sub enclosure that fits perfectly behind the double cab rear seats. It's designed to fit in the gap and have the correct capacity to allow the correct performance of the sub fitted. Also hidden out the way of prying eyes. Sounds good and makes the listening of any music much more enjoyable.
Amp is installed under the passenger rear seat so all cables are out the way and tidy 👍
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #569103 6th Oct 2016 12:25pm
Christian1402
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Indus Silver
That's a really neat solution! I like it.
You don't see enough silver defenders, I'll be taking some ideas off yours though. Keep up the good work Thumbs Up
Also, what's the air box mod??
Post #569132 6th Oct 2016 2:07pm
Roy5695
Thanks, the airbox mod is covered on the forum a few times but it entails removing the "cyclone" in the intake pipe and enlargening the inside of the airbox, inside the airbox is a cylinder that can be cut out to allow more air into the airbox. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #569138 6th Oct 2016 2:16pm
Christian1402
I see, it's the first I've heard about it. I'll have to look into that.
Can't beat free mods after all!
Post #569139 6th Oct 2016 2:18pm
Roy5695
Yeah there is a post in the search section which covers it, I used a soldering iron with a scrap tip to remove the plastic inside the airbox, leaves a smooth edge then. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #569142 6th Oct 2016 2:29pm
Christian1402
Perfect, thanks
Post #569143 6th Oct 2016 2:38pm
Roy5695
No worries,
Next on the list of things to do will be;
Coloured wing mirrors,
New front bumper for a spectre inspired one without the winch tray,
New front grill/light surrounds, 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #570783 14th Oct 2016 10:35am
Roy5695
Made it into LRO mag this month too Thumbs Up
Instagram - @r22oyp
Roy
Post #570829 14th Oct 2016 2:29pm
JOW240725
I spotted you! Well done Thumbs Up James
Instagram @suffolk_rovers
Post #570831 14th Oct 2016 2:43pm
Roy5695
Well a lot has happened since my update so ill add a few bits while I'm here;
gloss black mirror backs on,
front bumper on,
new front grill and light surrounds on,
rock and tree sliders on.
double din installed.
Think thats everything apart from a few minor details.
Oh and I also have a full set of Optimal race aluminium parts to fit;
window blocks,
bonnet hinges,
door hinges,
exterior door handles,
fuel cap. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #666035 21st Nov 2017 4:21pm
JOW240725
Looking great Roy! Thumbs Up It's always so shiny!! James
Post #666043 21st Nov 2017 4:46pm
Sulisuli
Great build thread Roy, will have to keep an eye out for you on the Cornish roads Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #666088 21st Nov 2017 7:49pm
Harry.O
United Kingdom 1989 Defender 90 300 Tdi ST Nato Green
Really smart 110 Roy! Did you paint or powder coat the rood rack? 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top
1992 200Tdi 90 Truck cab with Land Cruiser axles
Post #666095 21st Nov 2017 8:11pm
