![]() | Home > For Sale & Wanted > SOLD Factor 55 Flatlink in Blue |
John P Member Since: 26 Dec 2013 Location: West Sussex Posts: 347 ![]() ![]() ![]() |
Can you please measure the opening where the winch rope will go? I'm running 11mm synthetic rope, and just want to make sure it will fit?
Thanks John |
Japseroony Member Since: 02 Jan 2008 Location: North East England Posts: 843 ![]() ![]() ![]() |
Hi John, I was running an 11mm plasma and it fitted with room to spare but for info its approx 22mm.
You might need a larger shackle for the other end as that is approx 30mm and the smaller ones are not wide enough ![]() "UNDERSTEER" ----is when you hit the fence with the front of the car. "OVERSTEER" ------is when you hit the fence with the rear of the car. "HORSEPOWER" ----is how fast you hit the fence. "TORQUE" -----------is how far you take the fence with you. |
Hi Russell, I really like this idea, but my eye link measures 26mm. I only use 6 ton shackles, so the pin measures 26mm in diameter, so not sure if it will fit. On the website it say's it fits 3/4 shackles/D rings, so not sure if my shackles will fit. The opening of the shackle is 37mm so will probably fit around, but it's the size of the pin that worries me.
Can you please measure accurately? Thanks John |
Hi John
If your eye link is 26mm then this will not fit as the opening is only 22mm. Also the shackles you are using are no good as the pin hole is only 23/24mm, sorry. Cheers for the interest. Gas, Grass Or Ass - Nobody Rides For Free "UNDERSTEER" ----is when you hit the fence with the front of the car. "OVERSTEER" ------is when you hit the fence with the rear of the car. "HORSEPOWER" ----is how fast you hit the fence. "TORQUE" -----------is how far you take the fence with you. |
This is still for sale so reduced to £60 firm inc P&P to UK Mainland
taffrican Member Since: 14 Jan 2011 Location: Living room Posts: 625 ![]() ![]() ![]() |
You have a pm
![]() Pessimists say the glass is half empty.. Engineers say the glass is twice the size it needs to be! |
PM replied to
Sold and paid for
