![]() | Home > Maintenance & Modifications > Middle Row Seats Renault Scenic |
Simali Member Since: 25 Jun 2015 Location: Basingstoke Posts: 46 ![]() ![]() ![]() |
Ive seen a couple of threads (not here) on fitting scenic seats in the middle row of a 110 csw. I have Marky Boys modded 110 see here http://www.defender2.net/forum/topic30738....rear+seats
Problem is you sit very high and the seats are cloth and a ![]() There a lot of comment about its much easier with the earlier 3 individual frames rather than the later 2004 60/40 split. Any ideas welcom as i just dont have the budget to go exmoor premium. Can i buy the earler frame and fit it with minimal adaption. 2004 110 CSW (Called Yoda) |
Romadog
Did you have a 60/40 bench originally 2004 110 CSW (Called Yoda) |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1750 ![]() |
Yes it seemed that the holes suited a 60/40. There was no seating when I got it.
easy enough to fit puma middle row to td5, I did it in 2006, thread on here somewhere.
Love pumd seats but the bank balance says no ,! 2004 110 CSW (Called Yoda)
landroverdiver Member Since: 13 Jun 2009 Location: Renfrewshire Posts: 193 ![]() ![]() |
I took the 60/40 out of mine. Picked up a set of the 3 seat frames, painted them, put exmoor trim high back seats on and they are great. I had to buy the mounting brackets and catches, these add up to quite a bit, so unless you get everything from a donor vehicle it adds up to a few quid!
