Home > Maintenance & Modifications > Middle Row Seats Renault Scenic
Simali
United Kingdom 2004 Defender 110 Td5 CSW Zambezi Silver
Ive seen a couple of threads (not here) on fitting scenic seats in the middle row of a 110 csw. I have Marky Boys modded 110 see here http://www.defender2.net/forum/topic30738....rear+seats
Problem is you sit very high and the seats are cloth and a Censored to get dog hairs off
There a lot of comment about its much easier with the earlier 3 individual frames rather than the later 2004 60/40 split. Any ideas welcom as i just dont have the budget to go exmoor premium. Can i buy the earler frame and fit it with minimal adaption. 2004 110 CSW (Called Yoda)
Post #566531 25th Sep 2016 5:38pm
Romadog
I picked up a 60/40 set with all fixing brackets. This was easy to fit and works well. The earlier triple set may require hole drilling etc
Post #566538 25th Sep 2016 5:59pm
Simali
Romadog
Did you have a 60/40 bench originally 2004 110 CSW (Called Yoda)
Post #566578 25th Sep 2016 7:25pm
Romadog
Yes it seemed that the holes suited a 60/40. There was no seating when I got it.
Post #566581 25th Sep 2016 7:27pm
easy enough to fit puma middle row to td5, I did it in 2006, thread on here somewhere.
Post #566899 27th Sep 2016 7:42am
Simali
Love pumd seats but the bank balance says no ,! 2004 110 CSW (Called Yoda)
Post #568076 1st Oct 2016 7:38pm
landroverdiver
I took the 60/40 out of mine. Picked up a set of the 3 seat frames, painted them, put exmoor trim high back seats on and they are great. I had to buy the mounting brackets and catches, these add up to quite a bit, so unless you get everything from a donor vehicle it adds up to a few quid!
Post #568108 1st Oct 2016 9:09pm
