Home > Td5 > Windscreen frame removal TD5 2001 Non-air con
MC84
United Kingdom 2001 Defender 90 Td5 HT Chawton White
Hi, I need to remove my windscreen and frame. The rubber seal for the glass has failed but also there is some corrosion going on under the rubber and also I'm not confident with regards to how good the seal is between the frame to the body (roof and bulkhead).
I understand I can get the frame out by part lifting the roof/sides of the Defender. What I really need are the part numbers for the seals between the shell (the part I'm going to lift) and the base and the top and bottom seals for the windscreen frame.
Have I missed anything else I may need as I want to get everything on hand before I start. I have got the screen rubber and some glass sealant already. OH, and a new screen!
Thanks in advance
 Mike
Hard Top 90 TD5 2001
Ford 100e 1959
www.youtube.com/mikemakesit
Post #567099 27th Sep 2016 6:29pm
jst
if you undo the bolts holding the sides to the tub and the 10mm bolts along the top of the frame line (and A pillaer) you can lift the roof - just enough to get to the frame. you will need to wedge it up
then take off the hinge bracket fixings
you will need to split the gasket/silicon/sealent along the top to be able to separate the roof from top of the frame.
it wont lift out though easily. its held in location at the bottom by large locating lugs (like one that hold rad in place)
the frame is angled at the top to take the roof profile, remember that when trying to pry the sealant apart!
dont know the MPN but any parts supplier shoudld be able to help, the bottom seal is a self adhesive bit of closed cell foam with holes for the locating lugs cut in it, the top is just a line of thinner self adhesive foam. i use silicon on the top of the last one i did. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #567109 27th Sep 2016 6:58pm
dorsetsmith
LR055345 - BULKHEAD>WINDSCREEN SEAL / windscreen seal upper inner MTC4994
Post #567116 27th Sep 2016 7:13pm
MC84
Hi and thanks for the reply's. Another question if I may; What would you do, pay around £100 for a genuine LR windscreen rubber or buy a Britpart for less than a tenner? Mike
Ford 100e 1959
Post #567331 28th Sep 2016 2:15pm
Martin
Site Admin
Allmakes PR2 one, not the cheapo Britpart one.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #567333 28th Sep 2016 2:22pm
MC84
Unfortunately I don't know who they are. Can you elaborate please Martin?
Stop the Press, I found them but looks like Trade only? Mike
Ford 100e 1959
Post #567334 28th Sep 2016 2:24pm
Martin
Site Admin
Allmakes is a parts brand./group, just like Britpart. Supplied to parts companies only for them to retail.
They have a "Premium" parts range, with 2 year warranty on them - this they call "PR2".
I would recommend their windscreen seal, have fitted 2 now and they are fine.
Just one supplier, there are many others Smile
http://www.totalparts.co.uk/products/lr056...makes.html  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #567335 28th Sep 2016 2:27pm
jst
bearmach one for me Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #567336 28th Sep 2016 2:34pm
MC84
Once again thanks Martin and JST for your input. I've ordered the bits I need so fingers crossed!! Thumbs Up Thumbs Up Mike
Ford 100e 1959
Post #567341 28th Sep 2016 3:10pm
