![]() | Home > Puma (Tdci) > Developing transmission rumble and vibration |
Given your last para, I'd look at prop shaft UJ's first. The lift will have put additional strain on them, which would lead to the gradual failure you're describing. Darren
AJC Member Since: 30 Nov 2015 Location: Lancashire Posts: 1369 ![]() ![]() |
Could be something a simple as wheel out of balance
Absolutely agree. Chock a couple of wheels and let the handbrake off. Then hand check each joint. It's more likely to be the front propshaft. Do it NOW - it may get more dangerous/expensive. ![]() |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 ![]() ![]() ![]() |
I have a similar problem with my 110, only vibrates between the 1700 - 2000rpm range going up hill.
I have removed both prop shafts and theyre fine, gave them a good greasing while they were off, no movement or play anywhere else but it definitely feels like its in the drive line as it makes the gear box/stick shake and can be felt through the floor of the cab. hopefully you'll get a resolution. |
redline Member Since: 28 Jun 2015 Location: Mountains and Lakes Posts: 221 ![]() ![]() |
Gents,
Thanks for the replies. I doubt its the wheels: Firstly the tyres are new and newwly balanced and I have only been on highways since. Secondly, the accompanying noise and harshness is not characteristic of wheel balance issues. Driveshaft and/or UJ's ... Good points! I will check ASAP. What would be a permanent fix? Don't say "remove the lift" ![]() |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17725 ![]() ![]() ![]() |
No downside apart from the impact on your wallet, in fact any TDCi benefits from having a DC prop fitted in the front, it will remove the vibration issues that you may not even have noticed that you have. it is something of a mystery why LR didn't fit one in the first place, since the nose-up tilt of the engine and gearbox means that the two flanges are not co-planar and hence a standard propshaft can never be ideal. I imagine that LR figured that in a relatively agricultural vehicle nobody would notice a little more noise and vibration (unlike the Disco 2 where clearly it was felt that a more 'suburban' buyer would). |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2733 ![]() ![]() |
All Defender front propshafts are non-co-planar due to the 'nose up' angle of the front diff.
However the addition of a nose-up angle of the engine/transmission on Tdci models does make it worse. |
Cheers chaps! This forum is a fantastic resource ... really appreciate the knowledge that is shared on here
![]() I will check the UJ's tomorrow, but in any case will be ordering a front DC prop. Will report back with the results... |
tuesdayfox Member Since: 23 Jun 2013 Location: Sydney,OZ Posts: 129 ![]() ![]() |
following as mine also rumbles when I come off the accelerator.
my defender is MY13 2.2 defender and I have DC propshaft. I previously has 40mm lift with DC propshaft but no rumbles.... I recently removed the lift and now vibration when I off the pedal... very frustrating.... Cheers Martin |
agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324 ![]() ![]() |
Ahh, interesting point - so the phasing cant be optimal (as phasing can be) in a set up like we've got? Solved the bowel problem, working on the consonants... |
I believe (and it is a very long time since I studied the geometry and dynamics of such things) that the phasing of a drive shaft with two Hooke joints can only be optimal if the joint angles at either end are identical. Any deviation and the cyclic acceleration/deceleration becomes inevitable.
This is, of course, the benefit of the double Hooke or DC joint, since in effect it provides a very short additional shaft with guaranteed equal angles in the two joints. A propshaft with a double Hooke joint at both ends would probably do the job best of all, but is probably unnecessary. |
HI all,just an update...
today the vibration issue was solved....when I changed the shocks three weeks ago, I forgot the tighten two nuts on the left shock tower... But I will also add that, last week I thought the vibration was due to my rear prop shaft so I changed the UJs. this significantly reduce rumbling and cabin noise.... which is so noticable my wife ask what have I done... so there you go cheers Martin |
Guys - update on my end too: the UJ's were in fact pretty worn, despite the relatively low mileage. Attributable I believe to the lift placing undue strain on them, as pointed out by several of you knowledgeable folk... Also the lift affects the spline engagement on the shaft - although minor, it is noticeable.
The vehicle has been parked up since, and have ordered a front DC shaft which will be fitted ASAP. Will update once its fitted. |
Final update from my end: The DC shaft (front) has made quite a difference. I now have 7-800km on the new prop shaft, and can say that the car feels much more refined - less vibration in general, particularly at speed, as well as the rumble disappearing. Furthermore the slight steering resonance that I had at certain speeds has been eliminated. All in all, highly recommended for lifted TDCI's.
Thanks to all for the good advice! |
